9-5 Halogen to Xenon headlights - The Saab Link Forums
Old 04-23-2014, 07:17 AM   #1
bergie's Avatar
Has anyone on here done this.....i cannot find information on this anywhere.
I have seen the opposite working flawlessly however. SAAB 9-5 Xenon/ Halogen interchangeability FYI | theSAABguy
The plugs are identical...everything that is xenon specific is built into the headlight assembly itself.
I am thinking a simple Tech II edit and it should be plug and play.
Reason I ask is because I picked up a set of xenon's for reasonable money and thought about the conversion. I won't have any of the leveling bullshit to deal with(reason I didn't like them) and I will have a nice clean stock look over the morimoto conversion I am in the middle of.
I will end up finding this out by the end of the week for anyone else interested in doing this.
bergie is offline
Old 04-23-2014, 08:24 AM   #2
FreStylMotox01's Avatar
I did this on my 03 a while back with no issues at all, It was plug and play minus the auto leveling. I ran them for about a year before I sold the setup and the only issue I ever had was the high beam stopped working on one of the lights, but after my experience with the last two sets of xenons, I'm convinced that it was the headlights and nothing to do with the swap. The little relay that attaches to the plunger is pretty easily disconnected and ive had the issue with my current 9-5, a little solder and it was all set and like new.
So yes, you should be able to swap everything over with out issue. I didn't have anything done with the tech 2 on mine, so you shouldn't have to, but if you wanted the daytime running turned off to save the bulbs thats always a good idea.
FreStylMotox01 is offline
Old 04-23-2014, 08:26 AM   #3
P.S. how do the lenses look on your halogens? Any interest in parting with them?
Old 04-23-2014, 09:01 AM   #4
bergie's Avatar
Thanks for the Input. No one has documented this swap anywhere on the internet.
The lenses look fantastic on my halogens. They only have 102k with very little sandblast.
I will probably be parting with the complete headlights if this swap goes smooth and I am happy with the results. However Its a possibility breaking them up and selling the morimoto kit separate.
Look for a FS thread next week.
bergie is offline
Old 04-23-2014, 09:02 AM   #5
nowhereman's Avatar
and the autoleveling isnt too big a deal as long as you get the set to the same alignment first.
but yeah plug and play and the xenons are a huge plus. not to mention the bulbs are now cheap (comparitively) and can be had at autozone etc for about $100 per.
2008 9-3 SS: Stg 1
nowhereman is offline
Old 04-23-2014, 09:10 AM   #6
bergie's Avatar
Great. What do you mean by get the set to the same alignment first ?
Yeah I've had xenon's on my previous 9-5s and do miss them.
bergie is offline
Old 04-23-2014, 11:18 AM   #7
To make the cut off even on both sides.
Old 04-23-2014, 11:43 AM   #8
bergie's Avatar
Ok, the way it was worded confused me. Thanks for clearing up Jon.
bergie is offline
Old 04-23-2014, 01:27 PM   #9
nowhereman's Avatar
sorry that is what i meant.
the cut off on my parents 02 9-5 aero was no where to be found because some dofus pointed them towards the sky. highbeams useless no line on road etc.
i aligned them with my garage wall and a screw driver and now they are beautiful.
i think you sit about 5 feet back from the wall and make sure the cut off on low beams is about 2 inches below the height of the lights and going straight ahead.
2008 9-3 SS: Stg 1
Old 04-23-2014, 04:11 PM   #10
The instructions are out there somewhere, but it was something to the effect if parking 25 ft from the wall, measuring the marks in the head light lens, then adjusting it so it's 2 inches below that mark.
Old 04-23-2014, 05:25 PM   #11
bergie's Avatar
So just to clear this up if anyone is looking to swap oem Halogens to oem xenons. The headlights are a direct swap. I didn't need a tech II to program anything also the headlights retain the auto leveling feature.
As stated above the headlights should be aimed or checked to be sure there within proper specs.
When I was searching for this I could not find a legit answer anywhere on this. I heard stories from swapping lots of wires, even an abs sensor, to simple tech 2 programming needed.
bergie is offline
Old 04-23-2014, 05:33 PM   #12
NickTurbo900's Avatar
Shutters get frozen in the xenons... That is the only differnevce between high and low beams... The shutters are easy to free and lube with the whole assy out on a bench.
NickTurbo900 is offline
Old 04-24-2014, 08:05 AM   #13
bergie's Avatar
Oh how I missed my xenon's and projectors.....it's hard driving anything else without them at night, they make a huge difference.
bergie is offline
Old 04-24-2014, 11:21 AM   #14
srp
srp's Avatar
Send a message via AIM to srp
So the auto levelers are built into the headlight assembly? I thought they were attached to the suspension?
srp is offline
Old 04-24-2014, 11:42 AM   #15
nowhereman's Avatar
on my parents 02 aero the levelers are built into the assembly.
same on my 08 9-3 (which has the adaptive turn around corner lights weee)
i think its just the connection to make them work that requires all the fancy wiring etc.
2008 9-3 SS: Stg 1
Old 04-24-2014, 11:45 AM   #16
bergie's Avatar
The headlights will auto level themselves without these so called "sensors" or special wiring located elsewhere on the car. Maybe these sensor's are a myth.... I have no clue.
Everyone I talked to about this had no idea how they worked.
bergie is offline
Old 04-24-2014, 11:47 AM   #17
nowhereman's Avatar
Originally Posted by bergie View Post
The headlights will auto level themselves without these so called "sensors" located elsewhere on the car.
honestly that is what i thought as well. but i see all sorts of conflicting info and since i never did it myself i was lacking and mostly making educated guesses.
2008 9-3 SS: Stg 1
Old 04-24-2014, 11:53 AM   #18
bergie's Avatar
There is soooooooooo much conflicting info out there you are right.....These factory xenon headlights are a direct plug and play application.....everything specific to them are built right into the buckets.
bergie is offline
Old 04-24-2014, 11:53 AM   #19
srp
srp's Avatar
So without the other "sensors" do the headlights visibly auto level when you turn them on?
There are definitely sensors located through out the car that attach to suspension pieces.
There are plenty of posts about issues with them and backorder of parts.
srp is offline
Old 04-24-2014, 11:55 AM   #20
bergie's Avatar
Yes, the headlights will visibly auto level themselves.
bergie is offline
