02 Aero Wagon:::Recent Purchase - The Saab Link Forums
Old 10-24-2013, 02:19 PM   #1
sallythesaab's Avatar
So I had some extra insurance money from the Viggen accident and decided to pull the trigger on some winter wheels. Luckily I found a decent priced Aero wagon that needed a little TLC. It has 175k on the body and 145 on the engine. First engine was a victim of sludge. This one seems to be running strong! I'll be dropping the oil pan soon just make sure. So far I've replaced....
- All new vac lines. Most of them were cracked or broken.
- Inlet pipe to turbo o-ring along with clamp. Inlet was rattling against turbo.
- PCV hose to valve cover was torn
- New rear rotors and pads
- New rear struts
- CPS
Parts on the way....
- New engine mounts
- Coolant Sensor
First pic after driving it home from purchase
Dirty mess
loose!
Luckily I had some extra parts laying around
new struts, rotors and pads for the rear
Little bit cleaner
Made a custom divider for the dogs
Slapped some 16's with snow tread on, luckily right right before it started snowing!
Next week I'll install mounts, coolant sensor, plasti dip wheels black and apply 20% tint. Bars and snowboard rack should set me straight for winter!
2004 9-3 SS Linear (SOLD)
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
sallythesaab is offline
Old 10-25-2013, 05:12 AM   #2
I mentioned in the other thread, Burnsides migh wanna buy those fany rims off ya.
Old 10-25-2013, 05:43 AM   #3
Awesome.
BuHuSPG is offline
Old 10-26-2013, 01:02 PM   #4
niklauskegs's Avatar
Awesome ride man. I Recently bout a 2000 9-5 aero wagon and I'm having trouble diagnosing a rattlling noise from the engine compartment when I pull out from a stop, it goes away if I baby the gas pedal and once up to speed. I noticed you said you said you had a rattle noise due to the inlet clamp onto the turbo. I didn't know if you experienced something similar to me.
niklauskegs is offline
Old 10-27-2013, 04:15 PM   #5
That sounds a lot like a bad engine mount. How many miles? Any history on the maintenance? The rattle that was coming from my inlet pipe was a metal to metal rattle. It would go away under acceleration and sometime just cruising. If you feel a vibration in the car its probably your mounts. If there's no vibration definitely something else. I'd look at the clamp that holds the inlet to turbo.
I just ordered new mounts because I've got a crucial vibration in the car when I'm stopped with the my foot on the brake. Vibration goes away when its in Park or Neutral.
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
Old 10-27-2013, 04:17 PM   #6
I recently ran into some problems, started a separate thread in the "Problems" category.
https://www.saablink.net/forum/car-pr...only/80986.htm
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
Old 11-03-2013, 05:19 PM   #7
After three days of swapping parts from parts cars and installing some new ones along the way, the wagon is back at it!
I still can't pin point what actually made me break down last week but I did replace the following parts for this particular issue.
- CPS
- Coolant Temp Sensor
- Turbo, TD04 15t
other parts replaced...
- Right side top engine mount
- Front trans mount
- Top trans mount
problems found along the way...
- Only one bolt was holding the power steering pump on
- Seals into block are bad on water pump
- The engine and trans mounts were so worn, the engine was tilted down on the right side. Almost an inch. Believe this may have some effect on crank seal leaking.
Break down begins...
Removed original turbo
TD04 out of my '02 SE vert next to old one
Old top trans mount
Bottom trans mount comparison
Top right engine mount comparison
Installed
She started right up after installing everything. Engine mounts made a huge difference. Still need to order the rear engine mount. I sure its toasted as well. Plan on dropping the oil pan this week.
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
Old 11-04-2013, 07:15 AM   #8
bergie's Avatar
how do you like the 9-5 over the 9-3 ?
bergie is offline
Old 11-04-2013, 08:34 AM   #9
Good question. Still figuring that out. I'm definitely digging the space and comfort in the 9-5. Out of the box, 9-5 a better buy if you want the performance/comfort feel. I think the 9-3 can sometimes be more fun to drive because of the weight difference, little bit quicker. Think a lot of people would change their opinions about the 9-3 if it had rear independent suspension. My Viggen has way more upgrades than the newly purchased stock 9-5 so I try not to compare. If I had the same upgrades on the wagon it probably drive completely different. I'll slowly start to put some suspension/bushing upgrades on wagon as I get back in shape. Still has a lot of little issues to address.
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
Old 11-07-2013, 04:17 AM   #10
We had a warm day yesterday so I decided to put some tint on the windows and plasti-dip the winter wheels. I think it turned out pretty good.
step by step
Finally gave her a bath yesterday. snapped a couple pics this morning in different lighting. Unfortunately it was raining a little but still clean
Plasti-dipped the hatch emblems. First time doing that. Might go ahead and do the chrome on the front grille.
Probably going to order Thule rack this week along with snowboard rack attachment.
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
Old 11-07-2013, 04:32 AM   #11
Cark's Avatar
I love Aero wagons.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 11-07-2013, 04:52 AM   #12
nowhereman's Avatar
nice ride man. if i could find one in similar trim to yours id have it in a heartbeat.
2008 9-3 SS: Stg 1
nowhereman is offline
