Leaking green fluid * VIDEO* - The Saab Link Forums
Old 04-07-2013, 07:44 PM   #1
Saab95Aero's Avatar
Any ideas what this could be? coolant is about the same level as always
Saab95Aero is offline
Old 04-08-2013, 05:05 AM   #2
It's coolant. Now the fun part is finding out where it's coming from.
Wash the engine, let it dry and then run it to operating temp for a few minutes to open up the thermostat and start circulating coolant.
If you're lucky, it's a loose hose clamp.
Old 04-08-2013, 12:04 PM   #3
Saab95Aero's Avatar
A little update so today i looked under and there is a little more, its oily not watery i turned my wheel a few times left and right then turned my car off and a bunch of it started to drop out a good 15 drips then it stopped.
This is what i found today
Left side is power steering fluid i took off the dip stick, on the Right side is some of the green fluid i got from under the sub frame it is not actually green but yellowish..
this part has way more fluid building up in this exact spot ( right above the turbo inlet pipe)
Old 04-08-2013, 12:16 PM   #4
Coolant feels greasy to the touch.
If you want to be sure, taste it. It should taste faintly sweet.
Old 04-08-2013, 12:25 PM   #5
drink up!!!!
kidding!
Water pump sits right under the PS pump.
It's possible that the PS pump is leaking, but much more likely that the water pump is leaking, or at least weeping. Although, my 9-5 PS pump just gave up the ghost, at 165k.
Surprisingly, small amounts of engine coolant feel slimy, and PS fluid does not.
Neither will kill you if you tase 'em, but don't do more than a dab.
The good news is that if either is failing, it's not more than removing/re-insalling a handful of bolts to replace, and is a great way to build your shadetree mechanic skills. You'd just need about an hour for the PS pump, and about 2 for the water pump, since it's burried a little.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 04-08-2013, 03:01 PM   #6
Saab95Aero's Avatar
Originally Posted by g96nt View Post
drink up!!!!
kidding!
Okay so i lifted up the car and had a really good look i came to the conclusion its coolant and its most likely coming from the water pump, the pump made no abnormal sounds or anything car still runs fine but its dripping coolant poured in about a cup full today
Would me changing to a stage 3 tune and over sized filter make a difference or do you think one of the seals just failed in the pump?
What exactly do i need to install the pump is there a list of all the parts? how about liqid gasket?
Thanks guys!
Old 04-08-2013, 03:23 PM   #7
Nope. Aside from new coolant, the o-rings and the correct torx for the water pump, you won't need anything special. In fact, I think you only need the 18 and 16mm for the motor mount, the 13mm for the ps pump, intake bracket and water pump. 10mm for the bpv return and coolant return stays, (and the grounds on the thermostat if you change it) and the torx to take the water pump apart.
Think most people would recommend new hoses if you have never replaced them. There's a couple short ones one the passenger side, and a longer one on the drivers. I guess, if it were me, I'd replace or remove the coolant bypass valve. (I'd remove it)
Craig R.
g96nt is offline
Old 04-08-2013, 04:52 PM   #8
Saab95Aero's Avatar
What torx is it? i have a 205 piece socket set with a few different size torx will that most likely have it? what do you mean by the grounds on the thermostat? is the thermostat hard to do? i'm guessing its not to hard any special tools or is there e gasket for that also?
Thank you!
