01 9-5 temperature sensor issue? - The Saab Link Forums
Old 04-04-2013, 08:12 AM   #1
Hi,
I have a 9-5 with a 2.3T. Was smashed in front from hitting a deer. I got the car all back together with used parts. Now when I start it the engine begins skipping and the check engine light flashes. It wants to stall. After a little research I decided to replace the spark plugs, as I have no idea how long they have been in the car and it has been sitting at least 6 months since this repair. Sometimes it will run smooth for a minute or so then start misfiring even after the plug swap. My scan tool shows no codes but when I watch the coolant temperature while the car is running the dash gauge reads steady as it is warming up , but the scan tool shows the temp bouncing all around from -45 to over 400 degrees.
When it reads steady it runs fine, when the ECU sees the odd temp it runs bad, and I assume it is like a limp mode but I am not sure.
So my question here, if the temp sensor is bad, how is it that 1 gauge reads good but the ECU sees it differently? Are there 2 sensors? Or am I about to go on a search for wiring issues?
Any help would be greatly appreciated. I am new to these saab cars, hoping this issue is something kind of normal but with my luck you just never know!
newsaabguy is offline
Old 04-04-2013, 08:39 AM   #2
DrewP's Avatar
There is only one sensor. What scan tool are you using?
Check the ground lugs on the driver's side of the intake manifold, there are three of them, make sure they're tight in case they got loosened up during the repair.
Could also try just unplugging the sensor and see if it smooths out to isolate it.
DrewP is offline
Old 04-04-2013, 08:50 AM   #3
Easily's Avatar
i believe if it was in limp mode it would say check gearbox on the dash. a temp sensor would not cause irratic idle issues, i would x2 check grounds coming off the intake manifold. what kind of codes are coming up? there is only 1 sensor and its on the driver side head underneath the vaccum pump. (if i remeber correctly t7 cars had one coming off the valve cover)
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 04-04-2013, 08:51 AM   #4
Thank you! I will check grounds and give it a try and let you know how I make out!
Old 04-04-2013, 09:29 AM   #5
I am using a KAL equip scan tool, it is older. Was thinking it was suitable for this age car but maybe it isn't. It is a OBD II reader. I checked grounds, all seem tight and intact. I unplugged the temp sensor(on driver side) and the dash gauge didn't move at all but the scan tool is still showing numbers all over. The air temp here is around 45 degrees. The scan tool shows me the ambient temp and it is close so I believe it to be working. The coolant temp is crazy. With the car off and key on it reads a below zero number like -45. But soon as you start the engie it reads like 119F for a few seconds and it runs great, then it starts showing like 442F and bounces all over the place and soon as that happens it starts running terrible and the MIL light flashes. It isn't driveable like this and I would assume the flashing light is telling you not to anyway. The readout in the car doesn't flash any codes except for a signal lite I need a bulb for and an anti theft service. I was thinking the antitheft was due to a weak battery in the siren but could that be causing the car to do this? Still wouldn't explain the wierd temp reading on my scanner but maybe I need to try a newer scanner and see if that proves or disproves the accuracy of my scanner. Certainly appreciate the help! I will post more as I continue! Thank you
Old 04-04-2013, 09:58 AM   #6
FYI- my brother works at a shop locally, he is stopping over tomorrow to look at the car with me. We will verify the temp readings. His scan tool is a lot newer than mine.
Also, on the anti-theft note on the readout screen, I do not have a radio in the car. It didn't have one when I got the car.( I bought it smashed from deer hit).
The only code I have is for the coolant sensor that I unplugged to rule it out. Yet with that unplugged the temp was still going crazy. But the temp gauge never moved.
I will post tomorrow after my better scan tool is used!
Old 04-04-2013, 10:10 AM   #7
I'd check the plug for the coolant temp sensor. make sure it's not corroded or otherwise "gross". I suppose it's possible that the sensor is fine but there's a short. did the car sit with an exposed engine wiring harness? any possibility that a mouse made it's way into the engine bay?
New OE coolant temp sensors are $11. Get one, toss it in, and be sure.
Hell, I have one I'd send to you for free if you paid the shipping.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 04-04-2013, 08:47 PM   #8
I am not sure the temp sensor is a problem. My gauge works good but when it is unplugged my scan tool is still showing a temp. How is that possible? The dash gauge stopped working and it flagged a code for the sensor when I unhooked it. The scan tool and the dash gauge show two very different temps. Makes no sense to me.Something I totally overlooked is the air filter, no clue if there is a reason the engine cant get air. I will check that in the morning. Just to rule it out. Thanks to all for your help!
Old 04-04-2013, 08:48 PM   #9
wiring and plug for sensor look great. Clean and undamaged.
Old 04-05-2013, 08:33 AM   #10
OK so day two! My brother came over with a much more professional scanner. So the engine temp holds steady in dash and on scanner. Must be my scanner goes crazy when the car starts running funny. Maybe due to voltage fluctuation or something? Anyhow, prior to his arrival I tried something else. I pulled the MAF off the filter side of the tube so I could run direct air just to see if something was blocking air filter and choking out the engine. First try it ran great for about 3 minutes. I shut it off and restarted and back to same issue. after a few tried still same result. Running poorly after a 10-20 second period. The only code coming up is PO1300, a cylinder misfire code. I did install new NGK plugs gapped perfectly to be sure that was good. Did nothing for it. And it did have same NGKs in it already. so now I question a couple of things. The car has been sitting for at least 6 months. Any chance I could have crappy fuel? If these cars are so sensitive maybe poor burning fuel could give me these issues? Or could my CPS be working weird? Or even the DI cassette itself?? When I got the car it ran strange but I figured it was due to the fact the intercooler was busted open, but maybe the guy was running it like that? Hard to believe you could do it but who knows. He said it ran good but lets face it, he had a smashed car and needed cash! How could I test the DI cassette without buying one? I can't change everything just guessing, I'd like to determine the issue if possible.
Old 04-05-2013, 08:35 AM   #11
Another thought, could a bad injector do it? I'm not getting 1 specific cylinder misfire though. I think po1300 is random misfire?
Old 04-05-2013, 10:00 AM   #12
I may have found my problem. I did some more research about testing the Di cassette, basically found that you really can't test it. But I decided to pull it off and get a look after finding that 2000-2002 cars had a recall on the DI cassette for overheating the coils and failing. I removed mine, and can see a crack in the plastic cover that has the plug probes built into it. So 8 screws and the cover pops off pretty easily, had to know what was under the cover, moisture or whatever else. So what I find is that there is a resistor or something that is cracked and the resin that holds all the electrics is cracked in a few places, as if it got hot and split. So I think I am safe to assume this DI cassette is compromised enough to get another one. I doubt this car is able to get a freebe from a saab dealer but what the heck I am going to ask, I have a dealer still fixing saab cars about 4 miles from my work. Worth a call, worst they can do it laugh right?!
I will check it out and keep everyone posted!
Old 04-05-2013, 06:15 PM   #13
jssaab's Avatar
1300 is a bad DI change it ... Sid not see this till today.
jssaab is offline
Old 04-05-2013, 07:32 PM   #14
From the looks of the cracks in the resin inside the DI I expected it is the problem.
Why does it run good for a few seconds to sometimes a minute or so, then run like crap? Weird how it will do that, I would think it would just run bad any time you start it up. It is so consistently messed up that you couldn't really drive it anyhow. I will be getting a replacement! Thank you!
Old 04-05-2013, 09:49 PM   #15
Anybody in VT or NY have any leads on where to find a reasonably priced used DI cassette to try? I can get new ones from ebay starting around $110. My part number is 55562588 but it seems that there is another number more popular. I have no clue if this one is even the right part for the car. Maybe a newer version? This one is dated 0607, so June 2007 right?
Old 04-06-2013, 04:19 AM   #16
Do not buy one that is not oem. Cheap they are not. The best price is at car quest for 300.00. Order on line and they deliver to the store if they have any left.
Here is the link: http://www.carquest.com/webapp/wcs/s...1_125891_30643
Mike Brennan is offline
Old 04-06-2013, 07:04 AM   #17
Here's a question. When I look up new DI cassettes they are saying a part number 55559955 is it. Mine says 55562588. Mine is the black cassette, not red. Are these the same part with just a revised number or is there a reason for this? I don't find a new one with the same number as mine. I don't want to buy the wrong part and end up smokling my ECU or something!
Old 04-06-2013, 07:45 AM   #18
bergie's Avatar
just get a black DI your over thinking this, dont worry about part #'s just make sure it is an oem replacement and not chinese.
also take a look at the date code on the bar code sticker, if you get a used one obviously try and get one newer.
bergie is offline
Old 04-07-2013, 05:03 AM   #19
OK just didn't know if part numbers matter. Sounds like I keep hearing that these cars ignitions are so delicate, didn't want to mess it up with new stuff!
