04 9-5 engine into 01 aero ????? - The Saab Link Forums
Old 12-19-2017, 06:40 PM   #1
Have an aero with a blown rod..... im assuming the block is toast along with crank etc. I just found a 04 2.3t arc wagon out of a wrecked 04 151kmiles. QUESTION IS would i be able to use block/bottom end ???????
SABB-story is offline
Old 12-20-2017, 02:09 AM   #2
plug and play. You'll want to use the 04 throttlebody
seriks1 is offline
Old 12-20-2017, 07:25 AM   #3
Thank you seriks1 !
Old 12-20-2017, 09:55 AM   #4
DrewP's Avatar
The PCV setup is slightly different on the '04+ blocks too, so if it's coming out of a car get it with everything complete, including all the PCV hoses, and the hose running above the cam cover with the check valve. You'll notice that the snap fitting for the PCV hose going into the top corner of the cam cover is different when you look at it.
DrewP is offline
Old 12-20-2017, 11:32 AM   #5
Drew In Houston
There's also 2 different style ports (at least 2) for the intake manifold pressure sensors, that might be 01 and up or 02, it's right around then. Swapping the entire manifold fixes that, no problems. I guess generally if you see something different swap it from your old one
Trionic3000 is offline
Old 12-20-2017, 11:45 AM   #6
DrewP's Avatar
I don't know if I ever realized that, I don't think I ever had to replace a single MAP sensor on a T7 car! I love learning new things.
DrewP is offline
Old 04-19-2018, 06:36 PM   #7
So the yard never called me back on the 04 engine..... now i cannot find one... I remeber reading back in the day i may be able to use a older b234r bottom end with my 01 aero head.... ???? I am looking to run stage 3 possible a little higher with a 19t.
Old 04-20-2018, 04:23 AM   #8
There is a guy on SaabCentral selling parts from an 07 that has a bad fuel pump. Not sure location but worth checking. Engines for these cars are not hard to find.
BuHuSPG is offline
Old 04-21-2018, 05:10 AM   #9
jssaab's Avatar
Where are you. Bill Jacobsen has quite a few in DE at sports car service.
302 764-7222
Yes you can use a 234 bottom with your head. Quite a cew thngs to change up. I did write up here:
SaabCentral Forums - View Single Post - Making a Hybrid 234/235 engine
Just never posted all the part numbers for replacements
jssaab is offline
Old 04-25-2018, 08:43 PM   #10
Awesome WRITE up. I would love to be low 400s.... i drive respectable and wouldnt launch it. I wonder how the 234 bottom end would handle a tune... considering if the compression changes much??? I have a block with a piston threw the side.. so i have to buy block and rods etc..
