9k coilovers - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > Customizing Your Saab 9000
Customizing Your Saab 9000 This forum contains all CUSTOMIZING related Q&A's, such as Lights (taillights, headlights, turn indicators, clear corners, etc), Interior and Exterior modifications, Wiring, Gauges and more.
Old 10-30-2011, 07:51 AM   #1
Boosted92.9k's Avatar
9k coilovers
so as alot of you may know i made some coilovers a year or so ago now and kind of disapeared from the saab world... anyhow im thinking of selling my full set of coilovers and probably will be making more... you can search some of my old post and see pics of them and of my car with them on there they are still on it now so i will update photos soon if i get alot of interest thanks pm me for prices
Boosted92.9k is offline
Old 10-30-2011, 08:16 AM   #2
WSW
WSW's Avatar
Pics?
WSW is offline
Old 10-30-2011, 08:56 AM   #3
The Saab Link Forums - Boosted92.9k's Album: coilovers
Old 10-30-2011, 09:06 AM   #4
WSW
WSW's Avatar
What struts/shocks? whats the spring rates?
WSW is offline
Old 10-30-2011, 09:13 AM   #5
those have no shock seal/rod road water/debris protection.
Meaning they will require Constant maintenance just to stay alive.
bare is offline
Old 10-30-2011, 09:28 AM   #6
i made them from raceland bodies they are 350 lbs/inch front and 300 lbs/inch rear..... and as far as protection cause there is no plastic sleeve i know many peole running these brand coilovers and they dont have any problems
Old 10-31-2011, 03:58 AM   #7
tuner4life's Avatar
I would think that if you keep them out of nasty salty winter weather they will probably be ok. Most coilovers are designed this way.
How bounce were these? and, What would be ballpark price if you mass produce?
-Jason
1992 Saab 9000 Turbo - Cirrus White
1986 Saab 900 Turbo SPG Clone - Admiral Blue
1992 Saab 900 Base - Talladega Red
tuner4life is offline
Old 10-31-2011, 03:55 PM   #8
almost every coilover on the market they recommend every once and awhile to clean or at least just pressure wash the threads and bodies and they will last....and they really didnt bounce at all they road very well for being as low as it was...and if i was to make more i would sell the sets for $600 thats for a full set i wont just do fronts i only do full sets. Thanks for the interests
Old 11-01-2011, 04:06 AM   #9
tuner4life's Avatar
That's not a bad price for a full coilover setup!
-Jason
Old 11-01-2011, 06:25 AM   #10
Nick Taliaferro
GenuineSaab's Avatar
Its always the little bits of grit that get in the threads and make a nightmare adjusting. When we setup a car I always start by carefully powerwashing the threads or at least air blast if it has been out IRL for a while.
Saw a japan tuner car that they used overgrown leg/sweatbands around them to keep them clean. Not sure what they are called. Like the tops of tall socks.
Nicholas Taliaferro
GenuineSaab is offline
Old 11-03-2011, 05:10 AM   #11
come on someone must want a set of coilovers...i had people lined up the first time i talked about these to buy sets
Old 11-03-2011, 10:29 AM   #12
WSW
WSW's Avatar
I'm very interested but don't need the rear shocks
WSW is offline
Old 11-03-2011, 01:30 PM   #13
Svenska94Aero's Avatar
Send a message via AIM to Svenska94Aero
I would definitely be interested in a set, but I'd like to know how you solved the issues with the rear perches you talked about in your previous threads. Some photos and details would be really helpful. How much adjustability do they have; i.e. how do they compare to stock when they are cranked all the way up, and how low are they at the lowest setting? How bouncy/firm are they? What are you using for top mounts, just stock? Because stock mounts won't last long with the increased angles from extreme lowering, coilovers are best installed with adjustable pillow-ball mounts. As much info as you could possibly provide would be excellent.
1973 99 EMS - Big plans
1990 900 SPG - Go-kart with a Holset
1995 9000 CS - PITA
Svenska94Aero is offline
Old 11-04-2011, 01:12 AM   #14
Griffin dai's Avatar
+1 Also interested but need more info/pics. Also info on fitting...are these a bolt on upgrade or is there a fair bit of work involved to fit them?
GT3076R 9000 Aero.....dead
Stage 1 9-3 vert...alive....& too
slow
Griffin dai is offline
Old 11-04-2011, 04:53 AM   #15
SOAB's Avatar
I want coilover's so bad haha I want to make them on my own though.. how long were these struts? and I would be looking for rates more in the 500 range.
until something like this is available for saabs, there will be no slammage.
SOAB is offline
Old 11-04-2011, 07:40 AM   #16
Yeah, I'm kind of worried about the spring rates too, 350/300lb seems a bit soft for these cars, especially if you want to run dumped, or actually use them on a track like coilovers were originally intended. So I'm really curious about how the ride actually feels.
1995 9000 CS - PITA
Old 11-04-2011, 05:49 PM   #17
SOAB's Avatar
I probably feels fairly stiff but very compfertable.. my buddies runnin similar rates on his miata and it ROUGH
SOAB is offline
Old 11-05-2011, 07:42 AM   #18
these are a bolt in coilover no modifactaions needed they adjust up and down 3" they ride great for coilovers not bouncy and not to firm...as for pillow mount top hats if you look at any other coilovers on the market they hardley ever come with those... an adjustable pillow mount is an added option for camber adjustability but where as a saab doesnt have camber issues you dont need them
Old 11-05-2011, 09:26 AM   #19
Cool! Would you be willing to ship to the UK?
slow
Old 11-05-2011, 10:21 AM   #20
Aerohead's Avatar
I'm interested, need a set for my project 9000, but would also need further technical information to proceed. I plan to base my spring rates on the results of corner weighing after the main work is complete, nearly done taking stuff off.
Also interested in the Sweden one's you located Dave, know a native that can investigate and I'll report back.
Aerohead is offline
Tags
not gonna happen
