Puddle and Footwell Light Installation in OG9-3 - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 '94-'98 and 9-3 '99-'02 Forum > Customizing Your NG900 or old 9-3
Old 07-03-2011, 02:48 PM   #1
Hi,
I took 4 stock puddle lamps (4740494) and 2 stock footwell lamps (4740494) from a wrecked 9-5 and installed in my OG9-3.
For each of the 4 puddle lamps, which are located at the bottom of each door, the always-on 12v was taken from a +30 TEL0 connector behind the passenger kick panel. Earth was achieved by connecting to each door's pin switch. Hence, once a door is opened (and the switch makes earth) the respective puddle light turns on, and once the door is closed (no more earth) the light goes out. Simple.
The 2 footwell lights are located at passenger and driver sides under the dash. Power and ground was achieved by tapping in the front roof dome light's three-function switch. Power wires were routed down the right side A-pillar. The 2 footwell lights work in sync with the front and rear dome lights. Again, simple.
In total, I made four holes in the four doors and two holes in the plastic covers under dash. It was a clean and neat install.
Here are a couple of images with brief commentary of the installation process. In addition, there's images and a video of how it looks after the installation. I think that it looks awesome!
Enjoy!
PS Sorry for my English (I'm not a native) and for the poor image and video quality (those were taken with a phone).
http://youtu.be/OoHGkoE6iIA
The parts (it was actually 60m of wire)
New terminals and original black plastic connector
Lamp with the connector
Cutting through to chassis-to-doors rubber hose connector
Rubber hose connector
Wiring through the pins
Puddle light after cutting the hole and putting back the door trim
Wire and connector at a door
Wiring from rear door to chassis
Connecting additional earth wire to the door pin switch
Applying the original plastic terminal cover to the pin switch terminal
Tapping into the front roof dome light for footwell lights
Secure splitter for both footwell lights behind glovebox
Puddle lamp in the front door
Puddle lamp in the rear door
Footwell light in the passenger side
Footwell light in the driver side
Puddle lights
Footwell lights
Puddle lights
Puddle lights
johnbee is offline
Old 07-03-2011, 03:21 PM   #2
saabkid37's Avatar
looks like a pain in the butt, but nice job.
saabkid37 is offline
Old 07-03-2011, 03:37 PM   #3
WSW
WSW's Avatar
Bad ass..How long did the project take?
WSW is offline
Old 07-03-2011, 03:45 PM   #4
I'm a finance student and it took me 20 hours non-stop. It was tough, but I really wanted to do it! And it worked out perfectly.
johnbee is offline
Old 07-03-2011, 07:26 PM   #5
WyldSaabMan's Avatar
Where did you source the terminals and terminal shells?
Looks good. Good work.
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 07-03-2011, 09:20 PM   #6
srp
srp's Avatar
Send a message via AIM to srp
Wow. Love it.
Any pics of the foot-well light placement and install?
srp is offline
Old 07-04-2011, 01:09 AM   #7
The terminal shells (black plastic connectors) for lamps come from 9-5. The terminal shells (the transparent/white connector) for door pin switch is the actual shell that was there before. I simply took off the plastic shell. Undid the old terminal. Then put the two wires together in a new terminal and put the old white shell back on and connected to the switch.
I got the terminals at local electronics store. But as I'm not from the US the name of the store will be of a little use. Anyways, it is a standard and you'll definitely find those in many places.
johnbee is offline
Old 07-04-2011, 01:13 AM   #8
Originally Posted by srp View Post
Wow. Love it.
The installation of footwell lights was quick. Simply tap into the roof front 3-function light switch wires. Route them down behind the dash. Then use a splitter (image in the thread) or something, run a little bit of more wire to driver's side and passenger side and connect the lamps.
I added more images.
johnbee is offline
Old 07-04-2011, 06:32 PM   #9
secret ingredient's Avatar
Looks really good. I'm not interested enough in doing that to my own car to try it, but looks like you've done excellent work. I wouldn't have the patience.
1983 900 8v turbo- sold
1998 900 SE- sold
1995 9000 CSE
secret ingredient is offline
