boost gauge install questions (glowshift) - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 '94-'98 and 9-3 '99-'02 Forum > Customizing Your NG900 or old 9-3
Old 04-15-2011, 09:53 PM   #1
I want to wire it to the dash light fader. Im assuming that I hook up the red to that if I want the led to fade with the dash lights. What is the color of wire on the dash light fader that goes out to the dash lights??
Also, it needs a constant on power source (not turned on and off by the ignition. What is a good wire for that in the (back of the fuse box perhaps)?
Also, it has a headlight switch wire...what is the wire on the back of the round light switch knob that turns on and off?
Vee put vindshield vipers on aur headlights becaush ve are from Shveeden and it rainesh and shnowhs a laut en Sveeden!
jaross is offline
Old 04-15-2011, 10:01 PM   #2
josuar88's Avatar
Send a message via AIM to josuar88 Send a message via MSN to josuar88 Send a message via Yahoo to josuar88
For a constant power source I recommend using one of these and touching each fuse with the car totally off and the first fuse to light it up is a constant power as for the other stuff not sure
My Stand Up Comedy Page
I'm Not Poor Just A Saab Enthusiast
josuar88 is offline
Old 04-16-2011, 11:05 AM   #3
Ciscowned's Avatar
The glowshift gauges are LED and will not fade with the rheostat. LEDs require special regulators to do that.
Ciscowned is offline
Old 04-16-2011, 11:41 AM   #4
good to know! if I put a resistor on it- would that do the job?
jaross is offline
Old 04-16-2011, 01:38 PM   #5
Adrenaline406's Avatar
If we install LED's in our brake lights it set off the comand center, and you're supposed to throw a resistor inline to keep that warning from popping up (it senses amperage from what I understand). So I don't think that a resistor will do the trick.
To do this well, you're going to need a volt meter. Pull the rheostat out and find the ground. Then with the lights on, start testing other wires and see which one has a change in volts according to where you're moving the switch. That's your dimmer wire, tap and play! (Unless its LED like stated above).
Adrenaline406 is offline
Old 04-16-2011, 01:52 PM   #6
well it is led. What about the on/off wire on the lights switch? which one is it?
jaross is offline
Old 04-16-2011, 02:09 PM   #7
Same idea, find a ground and test wires with the switch on versus off looking for 12 volts.
Old 04-16-2011, 09:05 PM   #8
humm. the night dimming feature does not seem to work. I have the night dimming wire powered and its no different then without. eh, everything else works fine and its all installed now. I guess I could get some tint or something if it is too bright.
jaross is offline
Old 04-17-2011, 08:53 PM   #9
Danv's Avatar
https://www.saablink.net/forum/perfor...-9-3/44088.htm
Black Coupé 99 9-3 2.0L Automatic
Danv is offline
Old 04-18-2011, 10:17 PM   #10
thanks. i knew i had seen that before somewhere
jaross is offline
