Viggen Seats Installed + Wiring Info - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 '94-'98 and 9-3 '99-'02 Forum > Customizing Your NG900 or old 9-3
Old 03-27-2008, 10:39 PM   #1
ERP
ERP's Avatar
Send a message via AIM to ERP
Finally got my Viggen seats installed in my NG900. I could not find any wiring information and had to figure it out and guess on my own. A little scary when there is an airbag inside the seat, but it all went well and the seats are in and working. I kept track of the wiring to help anyone else installing Viggen seats in an older Saab.
The seats sit higher than the stock seats. Some of this is from a ˝” spacer I had to add, but they are still higher than that. The power buttons are also really close to the doors when shut. Makes is a little difficult to use them, but not too bad.
Here is a picture of the driver’s seat Viggen Plug
First, I highly recommend getting the body side of the plugs. The connection is very different from the stock NG900 plugs and would take a lot of splicing to get working. Using the original Viggen plug connection with a rat tail of wires is much easier.
The driver's seat plug harness is color coded to match the wires. The plug is gray, and the light gray crosses are empty connectors, the black connectors are grounds. 13 wires in total.
Seat Memory Box and Motor Wires
Red/Blue (12v signal)
Green: ? I did not connect it
White: ? I did not connect it
Large Red: 12v power – always on
Large Black: Ground
Seat Heater Wires
Red/Green: 12v signal
Medium Large Black: Ground
Green/White: ? I did not connect it
Air Bag (Yellow Box): Wires surrounded by a plastic yellow sheath, do not touch!
Brown
Blue
The green/brown and a black go to a plug under the seat but are not connected to anything.
Stock NG900 Driver’s Seat Wiring
#1 Black: 2.7v (Not a Ground)
#2 Yellow/White: Seat Heater 12v
#3 Brown/Black: ?
#4 Green: 12v power signal to Passenger Seat
#5 Black: Ground
#6 Red/Blue: 12v Always On
#7 Blue/Yellow: 0.7v, No idea what it is for
#8 Black: Ground
And the Passenger Seat Plug
Seat Motor/Relay Wires
Red: 12v always on
Large Black: Ground
Green/Yellow: Signal - Relay Ground
Seat Heater
Green/Red: 12v Signal
Brown
Blue
The remaining wires are not connected to anything under the seat.
Stock NG900 Passenger Seat Wiring
Black: Ground
Green: 12v With Drivers Seat Plug Attached and Key On
Yellow/Green: 12v Seat Heater
Blue/Yellow: 0.63v, 1v with Key On (I cut this wire and it had no effect on the seat motors)
Mounting
I used an 1/8” steel plate to mount the Viggen seats. The Viggen rails are ~ 2” wider than the stock rails. The motors on the Viggen seat also hang down lower than the stock seats. I used a ˝” spacer to raise the Viggen seats off of the steel plate to keep the motors from scraping. I also had to trim off a small tab from the inside stock rail that was contacting the Viggen seat rail. It is obvious when you see it.
Overall it was pretty easy, just time consuming to figure out the wires. The only thing I am worried about is that I wired the seats so that the relays are always on. This will be a small power drain on the battery holding the relays on and can potentially drain the battery over a long time if left to sit. But I would estimate this at a few weeks at least.
Enough writing, time to enjoy the seats.
2005 9-2x Aero Stg 2
1996 900 'Aero' 2.3t Sold -
ERP is offline
Old 03-27-2008, 10:40 PM   #2
Deez Nutz
Palmer's Avatar
Very nice.
S55/LC100/KL
Palmer is offline
Old 03-27-2008, 10:46 PM   #3
viggenkid's Avatar
Originally Posted by Palmer View Post
Very nice.
x2
viggenkid is offline
Old 03-27-2008, 10:46 PM   #4
User
zingZACH's Avatar
Excellent write-up! Wish more people would take the time and effort to make a write-up as good as this!
Also, the seats look great
1988 900 Springtime in Sweden
zingZACH is offline
Old 03-27-2008, 10:55 PM   #5
Nice write up and cool project.
Why dont the seats match up, would they be more bolt in like on a OG93 because its the same year? Do NG900 and OG93's match then? hmm...
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 03-27-2008, 10:57 PM   #6
NahumCC's Avatar
Just one of those subtle differences.
Now if you wanted to put viggen seats into a S/SE og9-3 then it would drop right in no problems I would assume.
2013 FR-S
NahumCC is offline
Old 03-28-2008, 06:43 AM   #7
stevehayes01's Avatar
Good write up!
stevehayes01 is offline
Old 03-28-2008, 02:44 PM   #8
t@llpum@'s Avatar
I didn't know the wiring was different in a ng900. Funny, I almost managed to get Viggen seats just recently - I would have ripped the old seats out and then gotten stuck, but now I have a reference. Awesome write up!
Come to STL and buy all (well most) my Saab's and take them away on a semi...please
t@llpum@ is offline
Old 07-20-2008, 12:55 PM   #9
stromer's Avatar
Awesome write-up, thanks.
So a 99 9-3 would have the same connector to accept the Viggen seats? What is if doesn't have power or heated seats?
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 07-20-2008, 01:26 PM   #10
Carl's Avatar
Send a message via AIM to Carl Send a message via Skype™ to Carl
All 9-3s use the same connector regardless of equipment. You will have to make wiring to enable the heaters and motors. I can be of assistance in this endeavor. Saab sells the terminals for the car side of the connector and you'd need switches out of an aptly equipped variant.
M00 9-3 Conv. B234 makes up for Sun Green
M73 99L In Maine
Carl is offline
Old 07-20-2008, 01:29 PM   #11
stromer's Avatar
Okay, so the same connector (at least it will plug into something) but the wiring for power seats won't be there? I'm not too concerned with the heaters, so I won't worry about that for now.
Is there an "old fashioned way" to wire the motors if you don't have power seats originally? It seems pretty simple, but how do you directly wire to distinguish between the "signal" and constant power wires?
stromer is offline
Old 03-18-2009, 08:11 AM   #12
stromer's Avatar
Long overdue update, but I figured I'd post up that I manged to get these seats wired. Well, Carl managed to get these seats wired....
But if you are attempting to do this, I think I could help answer questions you might have. Just let me know!
-Seth
stromer is offline
Old 05-20-2009, 07:18 AM   #13
You know what would look real nice is a 99-02 9.3 sport wheel, all you need is the wheel the bag and the upper steering column its pretty easy to change I can set you up with them let me know
SAABPRO is offline
Old 03-26-2010, 02:05 PM   #14
Aikmanson's Avatar
Looks awesome. I tried to do a seat swap myself in my NG, didn't work out too well to say the least.
Are you by any chance selling your old seats?
Aikmanson is offline
Old 04-11-2010, 06:08 PM   #15
Awesome.
I just got itsaviggn's seats and whomever mucked up the car and engine, definately mucked the seats up too. I had to swap the harness from one seat and the harness and tracks from the other. But the motors aren't aligning yet and the wires are still a mess.
Old 10-04-2010, 07:04 AM   #16
Electric seats
My son has a 1999 9-3 S convertible that was left outside with the top down, of course it was like a magnet for any rain in the area, and the rain ruined the seats. I found a set of seats from a 2002 SE convertible - so had to convert the manual seats to electric. The multipin connector seems wired just as Eric described for the Viggen - I have both connectors (seat and body). I spliced power from the cigarette lighter and everything worked fine..... except when I started the motor I get a dash light warning for the airbag system (presumably the system can tell that the blue and brown wires for the air bags terminate in the donor connector). So I examined the original connector (still attached to the car) and noticed as Carl points our the necessary wires are all present, but not connected (at least to the fuse panel). So I spliced power to the old connectors and the seats work fine - but I still get an air bag light even though the new seats have blue and brown air bag wires that match up with those in the original connector. That will likely interfere with the safety inspection process.
Does that mean the signal from the air bag wires is different in the 2002 SE than in the 1999 S? Can I do anything else? I can always pull the bulbs from the instrument panel, but that looks like a big job. Suggestions?
Pic attached.
Larry Mc
LarryMc is offline
Old 10-04-2010, 09:40 AM   #17
SevierSaabOG93's Avatar
Larry, Did you unplug the battery before wiring the airbags? because if you mess with them while plugged in then you have to have the srs light turned off via tech 2
SevierSaabOG93 is offline
Old 10-04-2010, 12:30 PM   #18
Thanks, did not always have the battery unplugged since I needed to test the seat before I bolted it in place..... I guess a Saab garage can reset it?
Larry
LarryMc is offline
Old 10-04-2010, 01:04 PM   #19
Marks9-3's Avatar
Connectors for the 99 and 02 will be the same. Big difference should be from the 900 to the 9-3.
Marks9-3 is offline
Old 10-04-2010, 01:46 PM   #20
I get the airbag light too, but this was going from 99 9-3se to 99 viggen. I think the problem is actually in the seat belt buckle. My SRS light was also on after the swap but did eventually go out on it's own.
