Quieting the JT 3" exhaust - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Classic 900 Forum '78-'93 > Customizing Your Classic 900
Customizing Your Classic 900 This forum contains all CUSTOMIZING related Q&A's, such as Lights (taillights, headlights, turn indicators, clear corners, etc), Interior and Exterior modifications, Wiring, Gauges and more.
Old 03-02-2008, 07:10 PM   #1
90SPG's Avatar
Send a message via AIM to 90SPG
So I have the 1 muffler version of this system and I would like it to be a little less wild on the highway and I would like to get rid of some of the inside drone. Has anyone ever added a 2nd muffler or replaced the standard JT one with something more quiet? A 2.5" would be a great option but I just cant get over spending that much for a new cat back.
Should I just turn in my man card now?
'90 900 SPG (RIP rust)
'86 900 SPG (DD)
'86 900S
"A car with an image so immaculate it can hold confession and communion."
90SPG is offline
Old 03-02-2008, 07:20 PM   #2
DeLorean's Avatar
I actually thought the 1 muffler JT system was pretty quiet. well... the exhaust noise was, it took me about... 6-10 tries to get it to sit right so I didn't bang into stuff left and right.
DeLorean is offline
Old 03-02-2008, 07:33 PM   #3
90SPG's Avatar
If you drive it conservatively it can be alright but it just pops and backfires far too much for my liking. I want to find a way to hear more the exhaust than just loud noise. But you're right it does bang the suspension waaay too much, a 2.5" might not be such a bad solution for all these problems, I guess I need to get practicing with the welder.
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 03-02-2008, 07:39 PM   #4
DeLorean's Avatar
well if I were doing things again, I'd use either a custom or JT 3" downpipe, and run that to a 2.5" pipe with a small glass-pack muffler. The full 3" exhaust is a hassle to get just right and unnecessary. Rather than going full custom 3"-2.5" ($$$ if you don't do it yourself) you could probably use the stock turbo exhaust attached to the JT 3" downpipe. your muffler choice could be basically anything that fits on the stock location, from a stock muffler to NO muffler!
DeLorean is offline
Old 03-02-2008, 07:39 PM   #5
I bought the JT exhaust with the 2 mufflers and it is perfect. I added the cat separately. Call Nick at GS and see if he can order you the second muffler from JT.
MickeyM
2006 Aero convertible
2000 9-3 silver convert (for sale)
mickeym is offline
Old 03-02-2008, 07:42 PM   #6
amish_geek's Avatar
Are you running with or without a cat currently?
I added a cat to my exhaust and I lost all of the pops and unnecessary noises.. and the exhaust tone lost about 10db in volume.
amish_geek is offline
Old 03-02-2008, 07:52 PM   #7
90SPG's Avatar
yeah it has a cat on it right now, I guess I'm just being a wimp about the noise.
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 03-02-2008, 08:11 PM   #8
Deez Nutz
Palmer's Avatar
I feel the same way about the JT in my 9-3.
I'll be keeping an eye on this...
S55/LC100/KL
Palmer is offline
Old 03-03-2008, 03:09 AM   #9
mcrowley's Avatar
The dual muffler/no cat setup on my 9000 doesn't pop or crackle much at all and its not loud at all on the highway (or inside the car) unless you're really on the throttle.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 03-03-2008, 06:18 AM   #10
Nick Taliaferro
GenuineSaab's Avatar
The cat and center muffler fix the popping.
Might be something in the throttle switch too, maybe too less decel fuel cut.
Nicholas Taliaferro
GenuineSaab is offline
Old 03-03-2008, 06:35 AM   #11
Legit's Avatar
So the 2 muffler no cat / race cat system would be the way to go for a clean sound?
2002 Viggen Convertible
Legit is offline
Old 03-03-2008, 08:01 AM   #12
90SPG's Avatar
Well I think I am going to order some 2.5" pipes and try to copy the bends in the 3" system when the time comes. Ideally I'd like to spend less than $100 on it which seems doable and hopefully I will have a quiet system that isn't constantly hitting the rear spring on corners.
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 03-03-2008, 02:11 PM   #13
spgproject's Avatar
here's an idea phil - why don't you just put a stock exhaust on the spg and put the jt system on the notchback?
-Sir William Lyons
spgproject is offline
Old 03-03-2008, 07:35 PM   #14
90SPG's Avatar
because I threw it away like an idiot.
edit:I should clarify, I don't have the stock system from the SPG anymore and the notch is exhaust-less, but I guess they are pretty cheap even new. The JT cat-back will probably end up on the notchback since I already have the DP.
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 03-04-2008, 05:26 AM   #15
amish_geek's Avatar
Wanna trade, straight up, for the 2.5" exhaust off my SPG?
It's just got a Cat + Thrush Turbo Glasspack (the red "cherrybomb" one). If you were at SOC, you probably heard it
Old 03-04-2008, 07:20 AM   #16
JK
JK's Avatar
I love the 2.5" thrush (or thrush-style) glasspack sound on a classic 900.
That's what my exhaust is, but with a very leaky downpipe. Its not even loud with a $Quarter$ sized hole in the downpipe, but the turbo wine is almost driving me nuts...almost.
always a SAAB guy at heart
JK is offline
Old 03-04-2008, 07:25 AM   #17
90SPG's Avatar
thats tempting, my friend has a 2.5" exhaust with a glasspack on it and is a great combination of sound and noise, it would be nice if you were closer so we didn't have to ship them. I think I might try making a new one first but if that doesn't go so well maybe we can switch them at Carlisle if youre still coming.
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 03-04-2008, 08:42 AM   #18
Bullseye's Avatar
Yes. You can reclaim it by purchasing your buddies a beverage at the next Saab club meeting.
Bullseye is offline
Old 03-04-2008, 09:03 AM   #19
90SPG's Avatar
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 05-11-2011, 11:19 PM   #20
93viggen's Avatar
I see that you do not like the sound of the jt 3"? I was curious, should I go with the abbott racing 2.5" with a cat, or a jt3" with a cat? I want it to be the quieter of the two..Also I have heard things about the cat being pointless because it blows it out or something, sorry for the inexperienced language/terms. I am new to this stuff. Thanks.
Using waste to make haste!
93viggen is offline
