Car runs like crap at my altitude. - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > Car Problems? Saab 9000 Only
Car Problems? Saab 9000 Only If you're experiencing problems with your Saab 9000 post your questions in here. CEL Code or GTFO!
Old 04-24-2012, 07:30 PM   #1
Send a message via AIM to dynaskiaero
I've been driving my car like this for months but I don't have much of a choice. I been living near Mammoth Lakes, California at 7500 feet and driving from around 7300 to 9000 feet all the time. Daily commute is 7400 feet to 8300 feet. Anyway I have replace a LOT of parts in the car and it hasn't made a difference for the altitude problems. Primary symptoms are Bad starts and sluggish performance, starts up at 400 rpm or lower and will run like crap until I give it gas. This makes it idle normally. The car also behaves sluggishly unless you rev it above 3000 rpms. On hills if you're stopped and take off its almost impossible to launch at a normal speed and if you slip at a low rpm it boggs wayy down and you can give it full throttle and it will do virtually nothing unless you rev it up and slip at a higher rpm which is a major pain in the ass. I have replaced the o2 sensors, plugs, and coolant temp sensor in the last few months. The car also has a JT 3 inch system all the way from the turbo and a recently replaced clutch with a bent pressure plate which I boogered myself. The clutch might have something or a lot to do with my take off problems. Recently its also started to misfire a little when its cold. I have no idea what the problem is, and theres no one around here with a tech 2. I could bring it to Walter Wong in LA but then the car runs fine down there and therefore he can't fix an issue thats not occurring. Need I say that my car passed the smog test about a week ago in Bishop, California at 4000 feet which is quite a bit lower. Help!
dynaskiaero is offline
Old 04-25-2012, 03:46 AM   #2
VI009DZ's Avatar
Have JZW tune it for you. I think he's a high altitude guy as well and might have some ideas on what to reflash to improve things.
-adam
VI009DZ is offline
Old 04-26-2012, 11:35 AM   #3
jk88's Avatar
That's a bummer. Give some free lift tickets to DrewP (and a couple to me brokering the deal) and we'll be up before season's end.
jk88 is offline
Old 05-01-2012, 02:26 PM   #4
mike d's Avatar
i would try to fix the hardware before a tune. Stock cars can still run at alitude ok.
That being said, Start with a good tune up,, you really cant diag these things untill you do,,
How many miles are on it? could it be a compression issue? just for giggles take a compression reading with it at altitude, i wonder what the lower air pressure will do to the numbers
MikeDTuning.com
mike d is offline
Old 05-01-2012, 04:25 PM   #5
mike9000aero's Avatar
I lived out in Laramie Wyoming. For a year with my 9k. And while the Turbo worked harder it seemed to idle just fine fuel Milagros was normal and it did not seem to loose much if any power
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 05-01-2012, 06:16 PM   #6
Drew in Houston's Avatar
Have you looked at all your vacuum lines very closely? Also the pcv check valve at the TB.
Drew in Houston is offline
Old 05-13-2012, 12:24 AM   #7
I would have him tune it but I'm a ways from CO
Old 05-13-2012, 12:27 AM   #8
It should have good compression its only at 92,000 right now I got it at 83,000 and it did sit for a long time. Seems to run great at altitudes lower than 4000 feet
