alright this is getting old....long - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > Car Problems? Saab 9000 Only
Car Problems? Saab 9000 Only If you're experiencing problems with your Saab 9000 post your questions in here. CEL Code or GTFO!
Old 11-11-2009, 05:22 PM   #1
mike9000aero's Avatar
ok so im still having my issue with my car cutting out (shutting off...stalling...whatever you want to call it) at around 5500 or up rpm
it only happends when in 2nd gear after a hard pull from first...under WOT at stated RPM it starts leaning out and then shuts right off...
things i have done trying to chase this issue down
1) fuel filter
2)walbro 255 (thought maby stock pump was getting weak, might as well upgrade while in there)
3) new used injectors...ran fine in friends stage 4 SQR car
4) FPR brand new
5) checked for boost/vac leaks...once at 25psi and also used a smoke machine for vac leaks
now about the car
97 9000 cse..full 98 cse drive train, td04, 3inch turbo back....large FMIC, JZW stage 3+ tune
No check engine lights now as i did have one for the front 02 short to b+ so i replaced the sensor but did not fix it, so instead of chasing wires i just replaced the engine harness...400+ miles with out CEL
history:
car was tuned when i was living in wyoming 7200ft elevation
came home to maine (sea level) car ran fine, perfect a/f all the way up to rev limit in every gear (12.5 a/f)
this was at the start of the summer in june
at the tail end of the summer mid september when outside temp started to drop the car started to have this issue
could it be that my turbo and IC setup is just out flowing my fuel system? i know that my car is at the limits for the turbo but with cold out side temps could the boost just be demanding to much fuel
some one please help this is really getting old
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 11-12-2009, 03:02 AM   #2
bump for wanting to figure this out
Old 11-12-2009, 09:18 AM   #3
132417SAAB's Avatar
Id hook up a fuel pressure gauge and see what that does when you hit the stumble
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 11-12-2009, 01:30 PM   #4
just tested fuel pressure....
idle is 38psi and full throttle at 6 grand when car shut off durring test fuel pressure was 64psi with a spike to 68
Old 11-12-2009, 01:55 PM   #5
also here is a picture of the plugs...wide band tells me its leaning out to an a/f ratio of 14.5 right before she shuts down on me
[IMG][/IMG]
Old 11-12-2009, 07:41 PM   #6
Injectors going past 100% duty cycle in denser, colder air? Id stay out of WOT if your AFR is going to 14.5...youre asking to melt something...
1996 SAAB 9000 Aero , Black on Black - SOLD
2001 SAAB 9-5 Aero, Silver on Black
MikesAERO is offline
Old 11-12-2009, 08:28 PM   #7
daveship's Avatar
Have you tried a new DI? When shits not quite right, always try another DI.
Good Luck,
Dave
daveship is offline
Old 11-13-2009, 04:35 AM   #8
yeah the only time im running WOT is to performe these test....and yes i do agree on the injectors just being pushed way to far...though my state ment to my tuner was...GIVE ME ALL SHE HAS GOT and i will upgrade later lol
dave, good idea, im going to toss in a brand new one from work today and see if that helps...thanks for the input
Old 11-13-2009, 06:48 AM   #9
JLausch's Avatar
Send a message via AIM to JLausch
Donno if this would apply for you, but i had some issues of a somewhat similar nature on my '91 turbo, i cleaned the contacts/grounds on my injectors and also found that my DI screws had backed out just a hair and it wasn't contacting correctly. The DI was most of the issue a that moment but it ran noticeably stronger after cleaning up the contacts.
'03 9-5 Aero wagon
'91 9000t (sold)
'90 SPG (sold)
'01 Viggen (sold)
JLausch is offline
Old 11-13-2009, 08:47 AM   #10
Old 11-13-2009, 08:52 AM   #11
lol, i know i know, but i got what i asked for and all was perfect untill outside temp dropped this fall past 50 degrees...
I have already lined up some bigger injectors, and will be ordering a 19t upgrade for my car in a couple months...in the mean time im not beating on it and its getting ready to go to sleep for the winter
how do those plugs look to you guys?
and lets not make this about your tuner as i literally had to fight with mine to get him to push my car this hard, literally 4 tunes to make me happy, the first 3 just did not give me what i was looking for...
my tuner advised me of the problems that could arise with pushing it as hard as i am, and i am fully aware at what could happen...
Old 11-13-2009, 12:13 PM   #12
so another question from me would be...
If my car is leaning out due to the injectors being over run with the colder air available, could i run a 3.5 bar FPR and maby get them to feed a little bit more fuel in up top?
Old 11-13-2009, 12:31 PM   #13
Legit's Avatar
Could it need a bigger fuel pump?
2002 Viggen Convertible
Legit is offline
Old 11-13-2009, 12:35 PM   #14
well i have a walbro 255 in there so i sure hope i dont need a bigger pump lol...and also the fuel pressure i think shows that im not having trouble keeping fuel in the rail
Old 03-14-2010, 09:24 AM   #15
Ok so I have a.new set up new. Tune and same provlem.
Semiens 630 injectors
3 bar map
And Holset, all other hardware is the same
I still have this same issue but realize that its not leaning out but rather just shuting down
Tags
wife beater
