Rear Doors Stuck? - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > Car Problems? Saab 9000 Only
Car Problems? Saab 9000 Only If you're experiencing problems with your Saab 9000 post your questions in here. CEL Code or GTFO!
Old 03-13-2009, 08:43 AM   #1
Svenska94Aero's Avatar
Send a message via AIM to Svenska94Aero
Rear Doors Stuck?
Okay, my rear doors are still stuck closed. I checked the locking system fuse, and it's still fine. I can pull on the handles, either inside or outside, and they come out to a point where they seem should release the catch, but the door itself just doesn't move. It's like someone put a deadbolt into them or something. anyway, it's really holding me up, as I need to get my c-pillars and headliner out and redone before the SIS show this year, and i can't remove the c-pillars without removing the seatbelts which i can't remove without moving the seats which I can't do with the rear doors closed....whew, you get the point. any pointers? if not, i'll just run it down to the saab guy and see if he can do something without charging an arm and a leg. thanks!
1973 99 EMS - Big plans
1990 900 SPG - Go-kart with a Holset
1995 9000 CS - PITA
Svenska94Aero is offline
Old 03-13-2009, 09:42 AM   #2
whoosh's Avatar
I had to remove the rear seats, removed all fixings for the door panel then pulled the panel away from the bottom rear of the door and reached up inside to pull the "arm" thats connects to the locking motor, have fun..
whoosh is offline
Old 03-13-2009, 09:44 AM   #3
nowhereman's Avatar
I know this is stupid... but any chance you just aren't pulling hard enough on the outside? the inside could have child locks on that would make it not work but on the outside i know on my gf's 9k the right side rear door requires a real hard pull (almost think you will pull the handle off). Don't worry about pulling it off though as if you do that will at least allow you to pop the latch manually. or take the latch on the inside apart and try that way..
2008 9-3 SS: Stg 1
nowhereman is offline
Old 03-13-2009, 09:49 AM   #4
VI009DZ's Avatar
Love those 9000 handles / locks. Of all the great stuff designed on those cars, the handles and locks suck wicked haaad.
-adam
VI009DZ is offline
Old 03-13-2009, 09:50 AM   #5
whoosh's Avatar
Its the little plastic clip holding the linkage to the door that normaly breaks so the motor cant pull or push the lock open.
As for pulling the handle off its bolted from the inside so would need some effort to do this.
whoosh is offline
Old 03-13-2009, 10:33 AM   #6
Moonracer's Avatar
When the door handles go bad on the 9000, I've found that pushing in on the door and pulling out on the handle will help.
Moonracer is offline
Old 03-13-2009, 03:32 PM   #7
Troup's Avatar
Send a message via AIM to Troup
Agreed...My driver side door wont open unless I push on the frame directly above the handle.
-1992 9000 T5
-1994 9000 Aero
-2004 9-5 Aero Wagon - Espresso Black
-2004 9-5 Aero Wagon - Glacier Blue
Troup is offline
Old 03-13-2009, 05:56 PM   #8
I took the rear passenger door handle off my parts car with a hammer to get the door open. Took bout 30 mins to beat it off those things are solid metal
This has a 'blowing up the Death Star' feeling to it! I for one, look forward to partying with some Ewoks and throwing an effigy of Ed Whitacre on a funeral pyre.
nickcannon413 is offline
Old 03-16-2009, 03:03 PM   #9
bobg450's Avatar
Doors stuck
Had the same problem- With the window down, remove the outer window seal on the door and look down at the mechanism with a flash light. You'll have to snag the arm on the little gizmo that releases the door latch. My mechanical child proof lock "switch" on the door near the latch was frozen between the two positions. That Parts Blaster PB kinda liquid wrench stuff works pretty good. Loosen it up with that, then white Lithium grease.
bobg450 is offline
Old 03-17-2009, 04:07 AM   #10
yeah, definitely, i had that problem with all my handles before, where i really had to yank on the handles to get them to open. i was the only one who could get into the car, even if the doors weren't locked. but now i can yank on them and lever on them and they just don't budge. thanks for the idea, though!
1995 9000 CS - PITA
Old 03-24-2009, 04:19 AM   #11
alrighty, i finally got around to looking into this: i spent 3 hours yesterday afternoon in 20-degree weather with a -10 windchill fixing the problem. i had to pull all the crap out of my hatch area and lay it on a pallet in my driveway. I then crawled in the hatch and over the back seats to remove the lower portions of the seats. then I pulled out the seat backs, and put all of it in another heap in my yard. I then was able to yank off the door panels and I pulled out the stupid foam sheet so i could see better. i was stunned at how much dust there was accumulated inside the door itself! looks like i'll have to get some baby wipes or something and clean everything down before i put it back together. on the passenger side, i found a pivot point on the lock linkage had broken (just a little plastic rivet) and the linkage had jammed, so that it wouldn't unlock anymore. i just yanked out that part of the linkage, since i didn't have an extra rivet. so the passenger side rear door can't be manually unlocked, but the power locks still work. the driver's side was weirder. i had everything pulled apart, and couldn't find anything wrong, but the door still wouldn't open from the inside. i had my brother yank on the door from the outside and it sprung right open, like nothing had ever happened. wth? i didn't even do anything to it, but now it opens from the outside, so no big deal. i guess something's screwed up in the child safety latch, so it won't allow me to open it from the inside. oh well. now im trying to decide if i want to put my rear seats/door panels back in, or strip everything down? any ideas how much weight i'd save by stripping everything from the back of the front seats back? except for the headliner, of course, which i will hopefully have pulled and sueded this week. thanks for all your help!
1995 9000 CS - PITA
Old 01-30-2018, 09:07 AM   #12
anybody know why my sab 9-3 estate rear hatch or fuel filler wont open on the key i have checked the fuse
mooseymoo is offline
Old 02-24-2019, 03:51 PM   #13
spanknut's Avatar
Friends used to say you have to open it like cj from San Andreas. Pulled the back seats once with the doors shut also. I believe it was Mike who said it ..push the door hard by the latch and pull the handle. Wd40 in the latch makes it work so easy it will blow your mind
spanknut is offline
