Engine runs cold in cold weather - The Saab Link Forums
Old 12-10-2014, 10:37 AM   #1
2001 9-3, 184k miles. In cold weather, temp gauge runs cool. In town, it gets up to temp eventually. But coming downhill from ski hill, or into an icy headwind on the freeway, gauge runs cool. In some cases, after ~30 min of running cool, temp gauge drops to zero, on comes CEL. The temp of the air from the heater mimics the gauge (cool gauge = luke warm air, normal gauge = hot air). There are dozens of Saab postings and they all point to thermostat. Had the thermostat and temp sensor replaced, seemed to work for a few days, then CEL back and same issue. Mechanic replaced both t-stat/sensor again, same problem returned a few days later. So for 2 years I've just lived with it. Mech has suggested that it is a head gasket issue, that this can cause issues with the temp sensor. But since the heater air seems to mirror the temp gauge, this seems like an actual TEMP issue, not a temp SENSOR issue. Car is acting exactly like the t-stat is stuck open, but I've already replaced it twice.
Anyone have this issue that was NOT a t-stat issue? Can a head gasket cause the car to run cold in cold weather? I don't have any severe head gasket issues as far as I can tell (certainly not consuming lots of coolant).
There have been 1 or 2 times in the summer that the temp gauge dropped to zero and the AC shut down, this was before all the work above, before t-stat/temp sensor were replaced. This was a long time ago and has not happened since, but I don't run the AC that often. Have never had an overheat issue.
viggers is offline
Old 12-10-2014, 02:41 PM   #2
Drew in Houston's Avatar
Sure sounds like a thermostat issue to me. I'd try a 3rd time but either put it in yourself or have someone else do it. They're cheap and not that hard to do.
Was there ever an incident where you got debris in there or someone put stop-leak in it or something? That stop-leak stuff hardens and can stay in there for a long time and jam things up--I could see it jamming a new thermostat same as an old one. If it has that crap in the coolant you'll want to drain/flush as much as possible. I hate that stuff; it doesn't work in the first place and once it's in there it's hard to get it out.
I can't think of a way that a headgasket or head issue would cause over cooling.
Drew in Houston is offline
Old 12-10-2014, 03:36 PM   #3
Thanks.....had come to the same conclusion about doing it myself. Seems the only way to get it done right these days.
The first t-stat replacement had the cooling system flushed. I've had the car for it's entire life except the first 20k, and never put any gunk into the cooling systems.
I like my mechanic, but until he can explain how a headgasket issue is causing the car to run cold, I think I'll spend the $1500 on something else......like a bicycle.
viggers is offline
Old 12-11-2014, 05:10 AM   #4
It is not a head gasket. First of all, you would have at least some other symptoms of a failed head gasket: oil in coolant, coolant in oil, low power, disappearing coolant, white smoke, oil leaking out of the side of the engine between block and head, etc.
I have purchased a bad thermostat before, so that is certainly a possibility.
The gauge dropping to zero and CEL sounds like a sensor, though. Since you seem to both have bad thermostat symptoms and bad sensor symptoms, I would guess there is another cause than just bad parts. I really like Drew's suggestion about stop leak; it, like many other snake oils, causes way more problems than solutions.
It can't be an entirely electrical problem, since the thermostat is a mechanical part. I agree that you should swap new parts in yourself. It is not a hard job. If they are all gunked up, it explains why they wouldn't work. Aggressively flush the car in that case. Flush many times until water comes out clean and clear with no sediment. If the weather is supposed to be above freezing for awhile, I have ran a car with water in for a day or two and flushed it again later. It was dirty again, even though it had been clean when I flushed it a day before. I think Drew's idea is very good.
You have asked an interesting question, I would be interested in hearing the solution when you find it. Please post your results for academic reasons!
BuHuSPG is offline
Old 12-11-2014, 08:01 AM   #5
2nd that, I'm curious what he finds.
I thought about the sensor issue too. That may be a problem as well, but even if it is, it can't cause the symptoms that he's describing by itself.
To cause too much cooling, the only effect a bad temp sensor could have is that if it were reading artificially too high, the controller would then activate the fan in response. And in that case, a properly functioning thermostat would close more, sending less coolant to the radiator (because the heat exchange became more efficient).
Old 12-11-2014, 09:05 AM   #6
I am saying a gauge dropping immediately to zero and causing CEL would be a sensor issue. A car that has been running for awhile, even with an open thermostat, would not be at zero on the temp gauge unless it was like, -40 outside.
I think both parts are failing.
BuHuSPG is offline
Old 12-11-2014, 06:05 PM   #7
Oh yeah for sure, I wasn't disagreeing with you at all. I think you're right.
All I was saying was that the gauge issue can't be causal for the cold running.
Old 12-12-2014, 07:11 AM   #8
Wagon Shaggin'
Saabeh's Avatar
I have had trouble with non OEM thermostats, perhaps this is plaguing you as well. Try the OEM Saab thermostat with o-ring available here: 30577561 Engine Coolant Thermostat (89 Deg) - OEM Supplier 26588 - Free Shipping
Looks like the "Saab" branded ones are no longer available, but according to eeuroparts, this is the OE supplier's part. As a side note, I will say that it seems silly that a non OEM thermostat wont function properly but I have experienced the same issue as you, and so has Mike D (who has changed 10x as many thermos as me).
Saabeh is offline
Old 01-14-2017, 11:53 AM   #9
Have you been able to fix the problem? My 02 9-3 SE has the exact same problem. . New sensor new thermostat. Code is P0116 cooling performance issue. I also went so far as to test the old thermostat after pulling it out. It worked fine. Replaced it anyway and also tested the new one before putting it in.
JadedWhispers is offline
Old 03-21-2020, 07:07 AM   #10
Hi!
Was looking for a solution for my 9-3 problem and found this thread.
Myne is throwing the P0116, and is running cold as well.
Although, it's running bad with missfires and wents on limp home mode on reverse or downshifting more agressivly.
I've already tried a new DIC (oem) and new spark plugs (NGK-R).
Does anyone think that this error will make this car symptons?
Thanks in advance
mvanastacio is offline
Old 03-23-2020, 07:45 AM   #11
New thermostat, gasket and temp sensor.
LEP3 is offline
