oil light occasionally at idle, at first drive of day - The Saab Link Forums
Old 09-15-2014, 04:35 PM   #1
I've had an oil light coming on for a few seconds, usually during the
first drive of the day in warm, not hot, weather, nearly warmed up,
after moderate revs and then moderately hard braking, at just above
idle, as it's dropping to idle. . The oil sump has a few carbon
granules (probing/scooping with a long popsicle stick), but I mean a
few....wouldn't say it is sludged up. I added an oil pressure gauge
via an oil filter sandwich adapter and the pressure there seems fine, if
not high.....that is, after warming up, ~22 psi at idle (1000 rpm), and
pins the gauge at 80 psi at about 3500 rpm. Cold, it is much higher of
course....40 psi at idle and pins the gauge at about 2000 rpm. My
question is, how reliable is the oil pressure reading taken at the
sandwich adapter (before the filter, not after as would be
preferred)....reliable enough to say oil pressure is fine? Details:.
running Mobil1 0-40w, 1999 9-3 SE with B204L engine, 234k. I'm
changing oil at 5000k but I don't know the history prior to the 3 years
I've owned it. Engine sounds fine, smooth & quiet, no tappet noise.
JohnZ is offline
Old 09-15-2014, 04:43 PM   #2
Is only trust a gauge installed in the factory location (on the back of the block). That's how saab checks them, and that's how I do it. You can find electric gauges that have a sender that will run both the gauge and the dummy light, or eliminate the dummy light since you now have a gauge.
If your motor is still quiet, I'd drop the pan ASAP and investigate/clean. Anything else is speculation.
Tboy is offline
Old 09-15-2014, 04:44 PM   #3
I know it sounds stupid but my brothers 99 9-3 SE and my friends Viggen had the same issue when they used Mobil 1. Once I told them to switch and try Rottella T6 in the cars the problem with oil light coming on low revolutions went away.
bseries93 is offline
Old 09-15-2014, 05:36 PM   #4
DrewP's Avatar
If you get 20 or so psi at the adapter at idle I'd try replacing your oil pressure switch and drop the pan and clean the screen and pressure bypass to be sure.
The stock sender should turn the light on at about 6 psi. Your sender might just be coming on too early.
DrewP is offline
Old 09-16-2014, 05:07 AM   #5
Thanks for the feedback. I forgot to say that I installed a new filter with the oil gauge. As I may be pulling it off again shortly, I bought a cheap one from O'Reilley.
JohnZ is offline
Old 09-19-2014, 11:17 AM   #6
DC_SAAB's Avatar
for whatever its worth and somewhat related.. I've seen where some folks have blown the seals at the turbo and lose oil pressure. Check for leaks near the turbo. Or blown Head Gaskets as well.. I had the experience of adding more antifreeze to my car and not seeing it go anywhere on the ground.. most times my HG blew internally.. and possibly by design.
Sounds silly but got in the habit of checking the oil for any discoloration on the dip stick.. and re-torquing the head every so often after major upgrades.
The simplest recommendation you eluded to early on.. is dropping the pan and cleaning that pick-up tube screen. But use high mileage oil with viscosity that applies to older cars.
DC
DC_SAAB is offline
