compression check - The Saab Link Forums
Old 07-26-2014, 07:21 PM   #1
gdc
compression check
Any body know how to do a compression check on a T5 2.0 turbo ?
gdc is offline
Old 07-26-2014, 07:23 PM   #2
Cark's Avatar
same as any other engine. Get a compression tester (~$25 at harbor freight), pull the DI and plugs, pull the fuel pump fuse, run your test.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 07-26-2014, 07:33 PM   #3
gdc
Harbor Freight ! ,
Thanks Cark,
Ive never done it on any other car, How do you run the test is it just use the compression tester, do I have to turn the engine over ?
gdc is offline
Old 07-26-2014, 07:48 PM   #4
Cark's Avatar
do a quick google search, some good tips on the procedure, but it's quite simple.
You will obviously pull the DI to get the plugs out, so no spark, but also make sure to pull the fuel pump fuse so you're not dumping fuel in! Only hand tighten the tester into the spark plug hole, if you crank it down hard you'll split the rubber o-ring and it will leak and show very low compression. Crank the engine about 5 times with the throttle wide open/gas pedal to the floor. This way air can get into the combustion chamber. If you don't open the throttle very little air will get in and you'll show low compression.
The goal of the test is not to look for a certain high #, but to look for evenness across all cylinders. Ideally they should all be within about 10 percent of each other. If you have one the reads much lower than the others, you've got a problem and more digging to do...
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 07-28-2014, 05:05 AM   #5
Wagon Shaggin'
Saabeh's Avatar
Having two people makes it much easier. One person controlling the key cranks and throttle, the other on the comp gauge.
Saabeh is offline
Old 07-28-2014, 05:57 AM   #6
Cark's Avatar
My comp gauge has a long enough hose I can hold it to the glass with a wiper blade so I can watch while I crank
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
