Problems after rebuild - The Saab Link Forums
Old 07-14-2014, 01:22 AM   #1
Hi all, hope someone can help me
I bought my missus a 2001 9-3 cab with a autobox, the engine (B205e) needed rebuilding due to a hole in the side of the block caused by conrod failure....
So i was advised to rebuild with a B205e block and to use the B205e head & Ancillaries which i have just done.
When it came to starting the car after the rebuild the engine will turn over, but soon locks up, I am 100% sure the timing chain is correctly aligned, And the engine will rotate for at least 6 rotations before locking up. If the chain was incorrectly aligned then it wouldn't rotate once.
Could the auto-box be causing this ?
Any other suggestion will be greatly appreciated.
Thank You
ian1973 is offline
Old 07-14-2014, 05:21 AM   #2
We once had our intake and exhaust cams swapped (done by our machinist and we didn't check). It was difficult for the starter to crank over and we smoked the starter before we figured it out. You can check easy, the exhaust can should have a slot or notch on the end where it used to drive the distributor (and on some models a vacuum pump).
Tboy is offline
Old 07-14-2014, 05:37 AM   #3
NickTurbo900's Avatar
Good thought, but an 01 auto should have the vacuum pump on the exhaust cam... only one way to hook it up.
NickTurbo900 is offline
Old 07-14-2014, 10:21 AM   #4
Is that when they started? I wasn't sure. My 99 auto had the electric pump. My 00 5spd does not have anything.
Not to be too far off topic, I am rebuilding the 00 5spd (aero) after 250 k miles. Everything was in good shape so there were no failures.
I was thinking about putting a cam driven vacuum pump on there just for safety, any reason I should not? Maybe I should start my own thread. Sorry op.
Tboy is offline
Old 07-14-2014, 02:08 PM   #5
cheers for the replies..... the cam on mine does drive a vacuum pump
Ive located the problem to be the thrust washers ! :/
I thought they were a little tight when fitting them but on the engine stand the engine turned over fine by hand, but ive never built a saab engine before, they have almost welded to the crank thrust faces purely on the starter motor, without even starting the engine
I hate this car already ! lolol
a few hours removing the alloy from the faces and the CORRECT thrust washers should hopefully resolve this issue :/ but doing more research has revealed another problem that i was mislead about... apparently i should of used a B204e head gasket when doing the hybrid conversion not a B205e Gasket !!!
ian1973 is offline
