Viggen AC System Question - The Saab Link Forums
Old 06-24-2014, 09:44 PM   #1
Moreboost's Avatar
I finally found time to charge the AC on the viggen. I plugged in the refrigerant hose and proceeded to try and fill the system but I immeditetly started hear hissing coming from behind the grille. I removed it to find what I'm assuming is, well was the high pressure hose port on the AC drier? Looks like it may have cracked and blown off, what ever the case the system obviously won't hold pressure. The port appears to be a apart of the metal line that's attached to the drier but for the life of me I can't find it anywhere. Eeuro shows a blow out diagram (#17 is a washer or gasket but that's the hose I need) when I try to look for it, it's not there. I'm tired of searching so I turn to you guys .
TIA
My car
Different drier same port?
Eeuro
Moreboost is offline
Old 06-25-2014, 02:15 AM   #2
Pretty sure that metal line and fitting are part of the A/C condenser itself.
Often the high pressure service valve or relief valve are replaceable but yours looks like the boss itself failed so even if the valve was a serviceable part, you're out of luck.
It's time for a replacement condenser.
win_k is offline
Old 06-25-2014, 08:59 AM   #3
srp
srp's Avatar
Send a message via AIM to srp
Yup. Condenser.
srp is offline
Old 06-25-2014, 10:04 AM   #4
Moreboost's Avatar
Damn, alright well hopefully someone on here has a used one that i can buy on the cheap
Old 06-25-2014, 10:21 AM   #5
srp
srp's Avatar
The newest-used one is 12 years old at this point. Buy new.
Get a receiver/dryer as well
Only $100 on SaabSite (Does Not Include Receiver/Dryer)
http://www.thesaabsite.com/93old/Saa...s.html#linkbar
Or $120 at eEuro (Includes Receiver/Dryer)
4758637 Aftermarket - A/C Condenser - Nissens 94504 - Free Shipping
srp is offline
Old 06-25-2014, 11:08 AM   #6
Moreboost's Avatar
The $120 is not bad at all and you're absolutely right about buying new vs used. What about this ebay one? Probably not worth the $30 savings
Universal Air Conditioner CN 4941PFC A C Condenser | eBay
Old 06-25-2014, 12:01 PM   #7
srp
srp's Avatar
I've got burned buying used AC hoses from a member here. So I won't make that mistake again.
Its probably the same condenser eEuro is selling, or made by the same vendor.
So might be worth a shot.
srp is offline
Old 06-25-2014, 04:04 PM   #8
WSW
WSW's Avatar
I'd stick with new with a/c components
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 06-25-2014, 05:24 PM   #9
Just a note if you do buy a new silver drier from eeuro it will be taller and if you have an after maket ic you need to bend the lines up just the slightest to make it fit so the bottom doesn't rest on the ic. I had to do this last year when I bought one works fine.
97 9000 cse stage holset
99 lb viggen jzw st3
foxracer52 is offline
Old 06-26-2014, 10:00 AM   #10
srp
srp's Avatar
Make sure to paint it black too so it doesn't show behind the grill.
srp is offline
Old 06-26-2014, 05:01 PM   #11
oliversexpedition's Avatar
Make sure that you spray PB blaster on the bolts holding the condenser and the dryer. You should limit the time that the dryer and the system is open.
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
