Replacing lower control arm - The Saab Link Forums
Old 06-23-2014, 10:20 AM   #1
Hi,
I have tried to replace the lower control arm on my Saab 9-3 99. I have successfully loosened the control arm from the subframe. But I am not able to loosen the ball joint.
I can see that it is a bolt on the upper side og the ball joint. Do I need to remove this bolt before I can loosen the joint? I hav etried hitting the joint with a hammer, and used a pickle fork, but it wont move. That is why I decided to post a message here before i risk breaking something. Hope someone can help me out.
trappetroll is offline
Old 06-23-2014, 04:09 PM   #2
VWSAABVT's Avatar
Did you take the nut off of the ball joint? If so I pry down on the control arm and hit the ball joint with a hammer and it usually pops out.
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 06-24-2014, 04:45 AM   #3
Since you are replacing it, do what it takes to remove it. I tend to get a pickle fork in there tight between the lower part of the spindle and the upper part of the arm, then attempt to undo the nut.
Vice grips are also your friend.
Tags
9-3, ball joint, lower control arm
