Little ac issue - The Saab Link Forums
Old 06-17-2014, 06:49 PM   #1
Little ac issue
So its getting to be that time of year that ac is need, and it feels as if my ac doesnt gets cold enough. I've got a jak Stoll intercooler which is slightly thicker then an ets. Last year I replaced the pump, drier, a line, and evaporator. Also had the system drained and filled 3 times no leaks it blows like 60 air after driving around for about 10 min. Is this just normal with an aftermarket intercooler?
97 9000 cse stage holset
99 lb viggen jzw st3
foxracer52 is offline
Old 06-17-2014, 07:26 PM   #2
oliversexpedition's Avatar
Did they pull a good vacuum and got all the moisture out of the system? What are the low and high side readings and what was the outside temp? If it was 100 deg, 60 might not be bad. Get a AC temp thermometer (probe) and get a good reading inside the car.
If you did it last year, if there is a small leak, might have to do it again. Not convinced that IC size matters, unless evap is bad.
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 06-17-2014, 07:51 PM   #3
Yea they pulled vac on it for 10 min I just can't remember what the gauge reading was cause I was standing right there. I had it done at a buddys shop and everything was fine even took it back a few months later to see of it was leaking with a UV light and it wasnt. It was like this last year too. I have a temp probe in my middle vent. I really should say that no matter what it doesn't seem like it gets that cold
