Fogs won't work an fuse is not broken - The Saab Link Forums
Old 04-24-2014, 05:13 PM   #1
Kevin dangas's Avatar
So I was changing my fog light on my pass side an they were on an when I went to put the bulb in in was all fine then I tryed to put it back in the housing then it went out so I pulled the bulb out an then put is back in the socket then poof the they both went out an the fuse is ok an the switch inside the dash is working or the light is on at least so now I am very confused any help would be sweet thanks o an the car is a 01 Viggen if that makes a difference
Kevin dangas is offline
Old 04-24-2014, 05:25 PM   #2
oliversexpedition's Avatar
Work your way backwards, are the bulbs still good? Avoid touching them with bare fingers. Use a voltmeter and are you getting 12 volts at the light socket, both sides of the fuse and relay?
Might also check if there is more then one fuse or fusible link?
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 04-24-2014, 05:31 PM   #3
Yah the bulbs are both still good I haven't really looked to far into it I wasn't sure if it was something simple I have over looked
Old 04-25-2014, 06:37 AM   #4
lms
Ground issue?
lms is offline
Old 04-25-2014, 07:31 AM   #5
Ground issues ? I don't know I went to change them an when I put the bulb in it seem to trip the other side off an the one I replaced didn't work also the fuse is all good an the switch could it be that the housing is some how messed up now cus of what happened they were both working prior to this happening it's just weird I was wondering if anyone else has had this problem
Old 04-25-2014, 06:44 PM   #6
NickTurbo900's Avatar
I can't even read your posts. Stream of consciousness is the term I believe...
You are the best able to figure this one out... and posting on a forum isn't going to help too much...
I've never had this problem.
Is there power and ground at the plugs?
Is there power and ground at the fuse?
Good luck with it but we can't fix it for you!
NickTurbo900 is offline
Old 04-26-2014, 10:34 AM   #7
Thanks I figured it out so nvm on this post anymore
Old 04-26-2014, 05:00 PM   #8
Well..
Just as you came here looking for a fix from someone that "had been there before"...
Fulfill your very own wish and tell us what exactly fixed it!
Old 04-30-2014, 07:00 PM   #9
Wednesday bump...
I put a fog light bulb in a 2003 Audi A4 3.0 today. While I was installing the passenger fog bulb, the drivers side bulb which remained on, then went out suddenly...
Lo and behold, the fogs are on a timer that the driver can set with a knob on the left hand side of the dash!
It made me think of you!
What fixed yours?
