NOx Emissions on the vig - The Saab Link Forums
Old 03-15-2014, 08:46 AM   #1
PAviggen's Avatar
Took the vig to the Air Care Colorado station for the pre-plates inspection...and she failed.
Prior to purchase, as you all know, had a mike D tune with all the hardware minus an IC and turbo intake pipe.
Since purchase, I've added the GS IC and intake pipe, and the car now operates at 5,300 feet where as the tune was at sea level. (no modifications to the tune)
HC GPM was a pass, CO GPM was a pass, CO2 GPM was a pass, but the NOx GPM came in at 2.3908 with a 1.5 limit and failed...after two attempts.
The test is run through 1st and 2nd gear up to 60, was about 52 degrees today.
Is this a matter of a re-tune or might there be a simpler and less expensive solution(s) to try first? The notes on this emissions test for high NOx say "High NOx readings are the result of high combustion temperatures and/or pressures"
FYI I ran the car at highway speeds, on and off boost for a good half hour before the test.
Any help would be much appreciated.
PAviggen is offline
Old 03-15-2014, 09:45 AM   #2
PAviggen's Avatar
aside from buying a used DP just for the test...
PAviggen is offline
Old 03-15-2014, 09:57 AM   #3
lms
Run the car in second and third, make sure they have a huge fan pointing at the front, run high oct gas, turn heater on full when testing.
lms is offline
Old 03-15-2014, 10:02 AM   #4
PAviggen's Avatar
Unfortunately they don't allow any modifications on the test. Unlike PA, Colorado has this "assembly-line" for testing and its state run. They test by the books without requests....
PAviggen is offline
Old 03-15-2014, 10:39 AM   #5
Maybe just find another center for the test, they could have a funky machine.
Old 03-15-2014, 11:15 AM   #6
DrewP's Avatar
If everything passed but NOx you need a catalytic converter, yours isn't working 100% anymore.
DrewP is offline
Old 03-15-2014, 11:27 AM   #7
PAviggen's Avatar
Sigh.
Instead of swapping in/out a used stock DP in hopes it would pass, I'm wondering if a Genuine Saab D/P with california obd2 cat would be a better investment. Anyone have experience with these?
The thought of removing the somewhat rusted 6pt subrame brace made me puke in my mouth...
PAviggen is offline
Old 03-15-2014, 02:26 PM   #8
oliversexpedition's Avatar
Had one fail with a race cat, but lack of cat will do it. See if you can get a Summit racing cat and have it welded or clamped in. I ended up with a 3" both sides for a 3" DP.
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 03-15-2014, 04:00 PM   #9
PAviggen's Avatar
Crossed my mind but was concerned about the placement of the rear O2 sensor. I know they can be fickle, and I trust Taliaferro's precise placement rather than a 3rd party welder. Choices, choices.
PAviggen is offline
Old 03-15-2014, 09:27 PM   #10
Drew in Houston's Avatar
If you don't have a wide band air fuel setup you should get one. Either AFR is off in those load ranges, or your cat is no good, or both.
Drew in Houston is offline
Old 04-04-2014, 03:28 PM   #11
PAviggen's Avatar
REALLY impressive results with the GS V2 DP with cali cat:
HC GPM 0.0551 (limit 1.2)
CO GPM 0.4728 (limit 15.0)
NOx GPM 0.1447 (limit 1.5)
No noticeable difference from the butt dyno either. Extremely happy with the results!
PAviggen is offline
