Viggen Death Knock - The Saab Link Forums
Old 03-13-2014, 08:16 AM   #1
ninehundredt's Avatar
Viggen Death Knock
Just noticed what sounds like rod bearing knock after getting home yesterday. I've reviewed this thread:
https://www.saablink.net/forum/genera...tion/49887.htm
I'm tempted to take tomorrow off from work and pull the pan to see how bad the damage is, but even if it is salvageable the weather here (Kitchener, Ontario) makes it difficult to complete a job like this since I don't have a garage to work in. No oil light has come on, and no mixing is evident. Oil also looks good. It doesn't sound like any debris is in there...just a constant knock which increases/decreases with engine rpm changes.
I'm wondering if anyone can give me a rough idea of how long I can get away driving it like this based on what I've described. The knock is mild, and I drive 10 minutes each way to work in city traffic every day. If I can make it to April I can pull my SPG out of storage and use that, rather than having to buy another SAAB right away.
I don't have a lot of time available to fix this, and was planning on getting rid of it later in the year anyway. If anyone is interested in a Viggen parts car let me know. It's still plated for NY (never got around to importing it to Canada). I think it will make it back to the U.S. ok if anyone is interested in coming to NY to pick it up. Otherwise there's always the crusher.
Cheers,
Chris
ninehundredt is offline
Old 03-13-2014, 08:52 AM   #2
After blowing an oil cooler line, I drove with audible lower end knocking for a couple of weeks. What I thought was rod knock turned out to be piston slap from overheated piston skirts whacking against the sides of the cylinder walls. Block needed to be pulled and rebored.
So, my advice would be to park it until you can check the bottom end bearings.
Old 03-13-2014, 09:01 AM   #3
Thanks Mike. I'm interested to find out what the cause was since I've been meticulous with oil changes and maintenance. I'll report back when I have an update.
Old 03-13-2014, 01:39 PM   #4
Drew in Houston's Avatar
Try removing or loosening the serp. belt and run it a little. Sometimes failing water pumps can have a similar sound. Maybe you get lucky?
Drew in Houston is offline
Old 03-13-2014, 02:05 PM   #5
It's worth a shot. I'll check it out. Thanks for the tip!
Old 03-15-2014, 08:21 AM   #6
As I suspected it was definitely terminal. I rolled the dice and attempted to make one last trip into work with it. Managed to make it into work for the day, but on the way home yesterday the engine seized.
I'm having a wrecker come get it soon, but figured I would see if anyone needs any parts. I'll grab what I can as long as it's not too much effort to remove. Let me know via PM if you have a request. Car is a red 2001 Viggen (4 door).
Old 03-15-2014, 10:00 AM   #7
lms
A wrecker, dude get that thing home and either put either a short block in it or at least strip it for parts, people pay good money for the body parts, seats, etc..
lms is offline
Old 03-15-2014, 12:29 PM   #8
If I had the means to do so I would. The bumpers front and back were toast, so no value there anyway. I grabbed the DI, grille, charge bypass valve, side trim covers, and some other knick knacks. The only thing I regret not taking are the seats, but the guys are going to hold them for me. They aren't crushing the car until after it's parted.
R.I.P. Viggen.
Old 03-15-2014, 02:38 PM   #9
turbojohnny's Avatar
I'm disappointed
turbojohnny is offline
Old 03-15-2014, 02:44 PM   #10
Originally Posted by turbojohnny View Post
I'm disappointed
Me too, but now I'll be able to spend more time on the SPG.
Old 03-15-2014, 07:57 PM   #11
93viggen's Avatar
Dude, part it out on here you will make WAY more money off of it then selling it to the wrecker... I would like to get the transmission from you if possible...
Using waste to make haste!
93viggen is offline
