Engine Troubles - The Saab Link Forums
Old 03-08-2014, 04:00 AM   #1
132417SAAB's Avatar
Engine Troubles
Okay ill keep this short but my engine likes to stall out when coming to a stop getting off the highway. If I downshift through the gears its okay but if I pop it into neutral itll idle at 500 and stall out. Also the gas pedal is doing weird things, basically the first maybe 1/4 of travel issues no response from the engine. What do? Tia
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 03-08-2014, 04:26 AM   #2
lms
Check for vacuum leaks, clean iac and make sure u r not in limp mode if your car has that.
lms is offline
Old 03-08-2014, 05:03 AM   #3
This....
Especially the IAC and all hoses leading to and from it. That big J-shaped one can sometimes work loose, or get a crack where it's clamped.
Old 03-08-2014, 05:34 AM   #4
132417SAAB's Avatar
I've clean the iac once already. I have another one so I plan on cleaning/swapping them out. Vac lines are have been replaced with silicone
99 9-3 se
132417saab™©
AKA "numbers"
Old 03-08-2014, 11:04 AM   #5
132417SAAB's Avatar
Would that explain the throttle issue to?
99 9-3 se
132417saab™©
AKA "numbers"
Old 03-16-2014, 06:41 AM   #6
132417SAAB's Avatar
Ive been messing with different aic valves and finding vac leak after vac Ive been fixing and for awhile I had a bit of a high idle around 1500 or so but the engine wasnt stalling out anymore so I lived with it. Now though for the past three days or so the car started to idle normally but then started to stall out and idle at 500 again. The more annoying issue though is this delayed throttle response bull.
So my question is this - can a malfunctioning aic cause a delayed throttle response or should I be looking elsewhere like the tps or something?
99 9-3 se
132417saab™©
AKA "numbers"
Old 03-16-2014, 07:51 AM   #7
turbojohnny's Avatar
Have you checked the vacuum line to your map sensor?
turbojohnny is offline
Old 03-16-2014, 08:21 AM   #8
132417SAAB's Avatar
It didn't look terrible but I can replace it anyway with some silicone
99 9-3 se
132417saab™©
AKA "numbers"
Old 03-29-2014, 11:20 AM   #9
132417SAAB's Avatar
Just tried a brand new out the the box aic valve and the car still doesnt like to idle along with the delayed throttle response. Im really starting to wonder about the tps now. All the vac lines are good, new plugs and it will get 24 mpg on the highway.
99 9-3 se
132417saab™©
AKA "numbers"
Old 03-30-2014, 05:57 AM   #10
Send a message via AIM to mlemorie Send a message via MSN to mlemorie
I was going to suggest your TPS as well. When I threw the junkyard engine into my car, I missed the TPS plug and had a lot of similar issues to what you are listing.
1995 900 S Eucalyptus Green
2.3l 5spd
Stage: Zombie
mlemorie is offline
Old 03-30-2014, 03:55 PM   #11
You might also need to lubricate the throttle cable; spray some penetrating oil into the cable sheathing near where it connects to the throttle body.
Generally, if you get a vac leak, it will idle high and stay high. If there is a hole in the IAC hose, it will not make boost properly, and/or it will idle high--it won't idle low and stall. Instead of throwing parts, you can measure the resistance across the terminals of the TPS and cross reference that with the WIS values. You can also see relative throttle position with an OBDII scanner.
-Cm
Cm452 is offline
Old 04-10-2014, 06:14 PM   #12
132417SAAB's Avatar
Gonna switch gears a bit here but I'd like to ask about the strut mounts going on here, as in how do i loosen the nut on top. I saw on the brothers ng900 the strut on the Allen key slot and room for a wrench but it doesn't appear to be the case on the 93.
99 9-3 se
132417saab™©
AKA "numbers"
Old 04-12-2014, 03:13 AM   #13
132417SAAB's Avatar
Jumping back to the engine sides of things yesterday with the temps over 60 the car would stall out everytime coming to a stop. Today with the temps under 40 its fine
99 9-3 se
132417saab™©
AKA "numbers"
