Whoa Rear Camber Dood - The Saab Link Forums
Old 02-09-2014, 12:58 PM   #1
132417SAAB's Avatar
Whoa Rear Camber Dood Plus Other Stuff
So Ive got some pretty gnarly negative camber and toe going on in the rear (bcuz race car). The measurements are...
Drivers side -1.7 camber and -0.85 toe
Passenger side -1.1 camber and -0.44 toe
Im looking at the shims from genuinesaab and was wondering if anyone had suggestions for what thickness I should get. Car is on stock springs and Im looking to it back to factory spec. (because good tire wear). Tanks!
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 02-09-2014, 02:07 PM   #2
Your camber is almost too low. Its negative 1.6 to 2.0 degrees but your toe is a little out. The shim width has a specific amount of camber/toe you can add or take out per width. It should say on the GS site
neilv is offline
Old 02-09-2014, 03:12 PM   #3
132417SAAB's Avatar
Does anyone know what the factory calls for the alignment?
99 9-3 se
132417saab™©
AKA "numbers"
Old 02-10-2014, 06:29 AM   #4
That camber doesnt' seem bad. Toe need correcting, though.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 02-10-2014, 08:49 AM   #5
Just a lot of neg. camber on rear tires won't wear them funny.
Bad toe will. I think my 9-3 used to have -2.2 or something like that, and it never wore funny. either way, get the shims and straighten it out; That'll fix your feathered/scalloped/loud tires.
Craig R.
g96nt is offline
Old 02-10-2014, 05:47 PM   #6
132417SAAB's Avatar
Fantastic thank you!
Also The car has a tdo4 with what looks to be the t25 lines and and oil feed is leaking pretty good, what size copper washer should I be getting?
99 9-3 se
132417saab™©
AKA "numbers"
Old 02-11-2014, 05:10 AM   #7
I want to say 14mm, but it's been a long time...
Craig R.
g96nt is offline
Old 02-11-2014, 05:19 AM   #8
Greek Mod
grkguy89's Avatar
i wouldnt bother with the GS shims.
just buy some metal body shim from an auto parts store.
Current Activity: Moderating
grkguy89 is offline
Old 02-11-2014, 07:18 AM   #9
Wagon Shaggin'
Saabeh's Avatar
Excessive negative camber will wear the inside of the tire more than the outside, but it wont be all cupped and bumpy.
Saabeh is offline
Old 02-11-2014, 07:44 AM   #10
If it's not a powered tire, the wear difference will be pretty minimal l for your average joe.
Craig R.
g96nt is offline
Old 02-11-2014, 07:46 AM   #11
I guess what im trying to say is that it's less important on the rear tires on a fwd. They're not powering or steering the car, and are pretty much just being dragged along
Craig R.
g96nt is offline
Old 02-11-2014, 09:09 AM   #12
+1, with "dragged" being what happens if there is too much toe-in. That will eat the inner edges way faster than neg camber, especially on un-driven/un-steered rear wheels.
Uneven wear like the above from neg camber is usually avoided by rotating tires (at least for me, so far)
'91 M5
'86 911 coupe
Bleedsblue is offline
Old 02-15-2014, 11:36 AM   #13
132417SAAB's Avatar
Okay fellas Ive got running issues with that infernal horseless engine thingmabob.
Car is dieing while coming to a stop and Im getting a delayed throttle response in 1st. The vac lines are shit and will be replaced tomorrow along with the iac getting a cleaning too.
I also have new plugs to go in as well. Whats the method of failure experienced with the tps though? Whats the best way to test it with my fluke meter?
99 9-3 se
132417saab™©
AKA "numbers"
