1999 9-3 convertible weird clutch issue - The Saab Link Forums
Old 01-27-2014, 07:26 PM   #1
Makeyousaab's Avatar
Hello all,
I have been having a rather strange problem with the clutch on my 9-3. After driving the car for several miles the clutch will become spongy and will not disengage. I know there is air getting into the system because if I hook up my pressure bleeder, pressurize the system, and then actuate the clutch I can see air bubbles coming out. Afterwards, the clutch will work properly for some small amount of time and then the same issue arises.
Other interesting thing is: this really only happens when it is hot outside. When the weather is cold ~30 degrees or so the clutch will operate normally.
I was thinking maybe the rubber hose connecting the blake fluid reservoir to the slave is old and the expansion caused by warmer conditions is enough to cause this?
Any thoughts/help is greatly appreciate!
Thank you in advance.
By the way....car is a 1999 9-3 convertible. ~220k. Slave cylinder is fairly new as I installed a GS lightweight flywheel, upgraded clutch, and viggen pressure plate within 30-40K.
~Dave
Makeyousaab is offline
Old 01-28-2014, 03:09 AM   #2
If everything else is new, probably the master cylinder. The not dissengauge part sounds like when mine went.
Old 01-28-2014, 04:26 PM   #3
thanks tweek. Is there a way to check it before spending the $$$?
It doesn't look like too bad of a job.
~Dave
