1995 Saab 900 se turbo fan not working - The Saab Link Forums
Old 09-13-2012, 03:49 PM   #1
the motor in my previous fan went out and i got a new one, found out the wire from relay to fan had got burnt with it (low speed) and replaced. now my relays have power and the wires from relay to fan are good, but my relays arent getting a signal to turn on. i ran a switch, from battery to 40 amp fuse, to switch, to relay (side pole) which when i flip it will force the fan to turn on, but i want to fix it properly. any ideas? and also when i take the cover off of the relay itself and i push the little metal thing to touch the relay it makes the fan turn on as well, so the problem is my relays are not getting a signal to turn on from the ICE module, so could it be burnt wires, the module itself? any ideas? any help will be appreciated. thank you.
viktuhh is offline
Old 09-14-2012, 03:37 PM   #2
i had a problem like this also, check your fuses for the fan in the fuse box in the engine bay. there is a 30 (big green fuse) and 45 (small red) in there that control the fan. check the fuses and see if they are blown. that was my problem and changing the fuses fixed it. hope this helps and good luck
MATTYOBUCKLES is offline
Old 09-14-2012, 04:11 PM   #3
i have checked the fuses and they are both fine, so im thinking my problem is the wires between ICE module, and relay box, or the ICE module itself...
viktuhh is offline
Tags
ice module, overheating, radiator fan, saab 900, wiring
