Replacing the lower control arm(s) help - The Saab Link Forums
Old 08-22-2011, 09:03 AM   #1
soccerrplyr's Avatar
My sister needs the driver's side front done for sure on her 2000 9-3se. Local mechanic says book time is 2.4hrs. Sounds really off to me though i've never changed one. Any words of wisdom or tutorials out there? Is it just a few bolts and a ball joint?
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 08-22-2011, 09:07 AM   #2
WSW
WSW's Avatar
Disconnect sway bar link,loosen stanchion arm bolt,loosen control arm bolt..The tricky part is breaking loose the ball joint from the housing.. But since your replacing it anyway you dont have to be careful and you can just about use any method to free it loose.. id use this eEuroparts - Ball Joint & Tie Rod Seperator Tool - # A410
or just use a big sledgehammer and keep hitting the joint till it frees loose
WSW is offline
Old 08-22-2011, 09:19 AM   #3
Turbo00's Avatar
Pretty much this. Supposedly the sway bar endlinks are prone to snapping, but mine was fine when I did the job. I replaced them anyway (with poly bushings, still only like $30 total), but ymmv. Loosen the stanchion arm where it connects to the subframe, this gives you some more wiggle when you're trying to get the torx bolt out of the control arm/stanchion arm bushing. If the balljoint starts to rotate as you're trying to get the nut off, stick a jack under that end of the arm to apply some upward pressure.
Turbo00 is offline
Old 08-22-2011, 09:53 AM   #4
Saab DIY at platonoff.com
Here are some pretty great write-ups with photos, glhf.
2001 9-3 SE HOT
Minibuddha is offline
Old 08-22-2011, 10:53 AM   #5
pitman's Avatar
if you never changed one its time to. http://www.thesaabsite.com/Saab%2090...eplacement.htm is a good one.
pitman is offline
Old 08-22-2011, 07:26 PM   #6
secret ingredient's Avatar
Easy enough if you read the write up and put everything back as you found it. Just buy a new swaybar end link, on the off chance it breaks.
1983 900 8v turbo- sold
1998 900 SE- sold
1995 9000 CSE
secret ingredient is offline
Old 08-22-2011, 10:36 PM   #7
For sure ^^^ Both of mine snapped when I did them.
2001 9-3 SE HOT
Old 08-23-2011, 04:44 AM   #8
I was a cheap bastard on a budget when I did mine, and only had one new end link. I got lucky the other didnt break. Now it just clunks, haha.
1998 900 SE- sold
1995 9000 CSE
Old 07-18-2012, 03:24 PM   #9
Is it possible to just replace the bushing?
lredus is offline
