Stuck Manual Transmission Drain Plug - The Saab Link Forums
Old 07-09-2011, 02:26 PM   #1
TurboSwede53's Avatar
Send a message via AIM to TurboSwede53 Send a message via Yahoo to TurboSwede53
Angry Stuck Manual Transmission Drain Plug
I decided today I would get the fluid changed in my 98 900S and the hex drain plug is being a stubborn S.O.B. It's had a thorough soaking and set time with PB Blaster, tried using steel breaker bars taped to the hex wrench and hit the plug and immediate area around it with my heat gun. I put my full 215# in to pushing and it hasn't budged yet.
Anyone have any other ideas that might help free the stuck plug? I have my car up on Rhino Ramps, so that should give you an idea of how much clearance I have (my drive was is rock to make things even more fun!)
TurboSwede53 is offline
Old 07-09-2011, 02:45 PM   #2
WSW
WSW's Avatar
Mine was on there pretty good as well, i used a long allen key and a breaker bar and just didnt give up till i got that plug loose...Try manuevering your body different ways so you can get more leverage and strength
WSW is offline
Old 07-09-2011, 02:51 PM   #3
I hear ya man! At one point I had taped two breaker bars to the long hex key with nothing. Since my legs are stronger than my upper body, I decided to try pushing the hex key with my right foot. Success!
Old 07-09-2011, 04:52 PM   #4
mcrowley's Avatar
Chisel.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 07-09-2011, 06:00 PM   #5
WSW
WSW's Avatar
good stuff, glad to hear it worked out
WSW is offline
Old 07-09-2011, 10:44 PM   #6
srp
srp's Avatar
Send a message via AIM to srp
That's what i did to mine as well. Made sure the hex was seated really well, then gave it one good swift kick.
srp is offline
Old 07-10-2011, 05:07 AM   #7
Aikmanson's Avatar
Not to steal the OP's thread but, how the hell do you get the fill plug off? I have a 2001 transmission, which has a 15/16th bolt it seems. It is nearly impossible to get any wrench on there.
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Aikmanson is offline
Old 07-10-2011, 06:13 AM   #8
WyldSaabMan's Avatar
I'm able to get a socket on there with a really long extension. I'm usually able to snake it by (slightly bend some of them) all of the lines in the way.
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 07-10-2011, 06:31 AM   #9
Yeah guys, make sure you get the fill plug off before you do the drain plug.
Old 07-10-2011, 07:02 AM   #10
Aikmanson's Avatar
my thoughts exactly, I can't even get my fill plug off let alone attempt my drain plug.
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Old 07-10-2011, 07:22 AM   #11
WSW
WSW's Avatar
Fill plug was much easier for me to remove as opposed to the drain plug... Both were a pita tho
WSW is offline
Old 07-10-2011, 07:29 PM   #12
fiveiron9688's Avatar
I think it's a 24mm plug. Get it on there tight with the extensions + breaker bar, and it'll move.
I also did the right-leg kick to get the drain plug off lol.
1998 900 SE turbo convertible
fiveiron9688 is offline
Old 07-11-2011, 02:17 AM   #13
NickTurbo900's Avatar
The worst ones I've needed a air hammer with a sharp cold chisel to cut into it and get it rotating.
NickTurbo900 is offline
Old 07-12-2011, 01:19 AM   #14
bogan's Avatar
To get my fill plug off I put a ring spanner on the plug and used a piece of wood to lever the spanner of the strut brace.
On the drain plug I used a pipe extension on the allen key and my massive guns
bogan is offline
Old 07-12-2011, 08:01 AM   #15
Aikmanson's Avatar
I am hoping that the massive amount of grease my axle boots were throwing helped lubricate everything up
I will attempt it again when I have the time and motivation.
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Old 07-13-2011, 09:19 AM   #16
Castor Troy's Avatar
Audi C5 S6 Quattro 4.2 > Tools > Hand Tools > ES#11416 Impact Screwdriver Set - PCS2800
that is how i've had to get mine out before. have to be careful you dont hit too hard and crack the trans case though
Castor Troy is offline
