Cranking, No start - The Saab Link Forums
Old 09-22-2010, 01:56 AM   #1
Exclamation Cranking, No start
2000 9-3 convertible 2.0 :
Over the summer my Saab would intermittently not start. Engine would crank, but no start. After waiting 20 minutes or so, it would usually start right up. Last week it would not start period.
What I have done so far (after researching myself online):
Replaced the direct ignition cassette,
Replaced the crank position sensor,
Replaced the fuel pump.
Still no start.
I put a code reader on the car and do not get any codes, Im sure whatever codes were stored were wiped when i disconnected the battery to install the DIC.
I am not a mechanic and have no special equipment. But I need my car running and am running out of money and ideas trying to fix this issue.
Can anyone point me in the right direction? What can I do to check possible issues?
Thank you.
azpilot is offline
Old 09-22-2010, 02:58 AM   #2
BurnsSide42's Avatar
Grounds - start there, clean and repair all of them. Check for injector pulse - be sure they are firing when starting - this will rule out or in the fuel/electronics. All fuses check good? Cover the basics too - never forget the basics.
Check out
for your repair needs
BurnsSide42 is offline
Old 09-22-2010, 04:58 AM   #3
VI009DZ's Avatar
Although you've replaced the fuel pump, take the rubber boot off the inlet to the throttle body, open the throttle body by hand and give a good shot of starting fluid down into the intake manifold then crank. If you still don't get ANY sputter, then you've got no spark.
Another quick way to check for fuel pump operation, is to (with the key OFF!) crack open the banjo bolt on the fuel rail that feeds fuel to the injectors. It'll piss and spray fuel for a minute, but open it up and bleed off ALL pressure. Once its done leaking, tighten it back up, go and crank on the car for a few seconds again. Go back to the banjo and crack it up open again. If fuel squirts / sprays out again, then your pump is working, and again....spark is the issue.
As said above....check all of our grounds and fuses. Most likely NOT a fuel issue, but you never know, and a can of starting fluid is $3.
-adam
VI009DZ is offline
Old 09-22-2010, 06:13 AM   #4
you know mine has done that too, i did the same as you. I did check pressure it was good (careful its a bitch) i checked grounds and everything has seemed okay. HOWEVER i have jiggeled the key when it was doing a long crank it seemed to work. I also replaced the champions that where in it (they where from i guess 2006 when the guy took the car in) and it seemed to start shortly after a week. so dont know if its the plugs killing it they are ngk bp 7 es or something like that. Napa told me that SAAB changed their numbers for the oem replacement
Forced_2.0 is offline
Old 09-22-2010, 06:23 AM   #5
Trollerator
abdukted1456's Avatar
crank position sensor?
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 09-22-2010, 06:57 AM   #6
he replaced it
Old 09-22-2010, 07:31 AM   #7
Wagon Shaggin'
Saabeh's Avatar
Does that tach bounce on a T7 car when the CPS is good?
Saabeh is offline
Old 09-22-2010, 07:49 AM   #8
Trollerator
oh yeah, I guess it helps to read the whole thing
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-22-2010, 07:51 AM   #9
Perhaps the ignition swtich is going bad - but that would create a No Crank No Start symtom...
Check out
Old 09-22-2010, 02:06 PM   #10
It will start and then die after a few seconds, We've got spark...
I feel dumb for asking, but where is this located?
When i turn the key to "on", i do hear the fuel pump. I was wondering how to check if the fuel is getting to the throttle body now... Again, I have no special instruments to measure pressure.
Thank you everyone for your suggestions so far.
azpilot is offline
Old 09-22-2010, 02:12 PM   #11
I want to add, I checked the fuses and replaced one bad 30 amp. still no start
azpilot is offline
Old 09-23-2010, 05:27 AM   #12
Trollerator
there is a schrader(?) valve on the fuel rail. if you wear some safety glasses and have a rag, you can (carefully!!!!!) depress the little release in the center and it should spray gas out. if it just dribbles or nothing comes out than you don't have pressure at the fuel rail, fuel is not making it there.
I am sure there is a better/safer way to test but I did this to diagnose my suspected failed fuel pump and sure enough, a only few droplets dribbled out and there was no pressure behind it... yep, fuel pump.
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-23-2010, 05:51 AM   #13
Ok thanks for that. Nothing coming out when i depress that. Fuel pump already replaced. Does that mean the check valve is bad? if so which one...
azpilot is offline
Old 09-25-2010, 04:10 AM   #14
you could have a clogged fuel filter. not sure on the valve
Old 09-27-2010, 08:10 AM   #15
Trollerator
yes, the fuel filter is dirt cheap and easy to replace. Might be worth it to try that. If no fuel it getting to the rail, something is either blocking the line, or not pumping fuel (bad pump or bad fuse or no power to the pump) right?
I actually know of a 9-3 or ng900 that was abandoned because the mechanics tried "everything" and could not make it start. Then a Saab tech picked it up for nothing and put a new fuel filter in and it fired right up.
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-27-2010, 09:18 AM   #16
VI009DZ's Avatar
I'd look at the top of the tank and make sure that whoever did the fuel pump work, didn't put the feed and return lines bass-ackward when they reinstalled the pump. I forget exactly how they work, but one is the feed, and it only allows fuel out when the car is on its wheels (if it rolls over, a little ball valve closes and stops fuel flow) and the other only allows fuel to dump back into the tank. I think if they reversed them, then you would get no flow at all. Check that before you replace the fuel filter.
A clogged filter will still allow the car to at least run, and they don't clog instantaneously. If your car was running, then it died and you had the fuel pump replaced, start there.
-adam
VI009DZ is offline
Old 09-27-2010, 09:24 AM   #17
VI009DZ's Avatar
I feel dumb for asking, but where is this located? .
This is a 9k motor, but yours should be similar. Look at the "2.0" on the valve cover, and see the hose, and bolt head just up and to the right of it? About 1:00?? If you loosen that, fuel should spray out if your pump is working properly. If you loosen that and get a trickle, then tighten it back up, try to start the car and loosen it again. If you don't get a PSSSH!! of fuel then you've got pump issues. Maybe not the pump, but definitely something related to what was worked on last.
-adam
VI009DZ is offline
Old 09-28-2010, 02:07 AM   #18
Thank you everyone. Turns out there is a small clear plastic cap on the bottom of the fuel pump. Should have a "remove before flight" streamer attached to it
I removed the pump, saw the cap and removed it. Car runs like a champ now. Sheesh.
Again. Thanks everyone!
azpilot is offline
Old 09-28-2010, 02:12 AM   #19
LOL, when I changed the pump in mine in Feb I read an online article that stated that very fact first thing because that guy even forgot, glad you found it out without replacing more parts Hope you didnt have to cut a hole in the floorpan under the rear seat like I did to get to the pump.
1994 Saab NG900 SE 2.0L Turbo 5-Speed
Sorry Auto Always Broken
2006 Mazda 3 1.6L 104hp
Most Always Zipping Dangerously Along
Unreal2004 is offline
Old 09-28-2010, 05:49 AM   #20
Aikmanson's Avatar
cutting a hole makes it 10 times quicker, so I hope he did
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Aikmanson is offline
Tags
cranking, no start
