the infamous rough idle - The Saab Link Forums
Old 07-29-2010, 06:16 PM   #1
Greek Mod
grkguy89's Avatar
i swapped out my b234i for a b204r
and now have a rough idle with a vacuum at about 11-13 inHg
cant seem to find any vacuum leaks though
i checked engine timing and everything lined up
plus is seems like im running extremely rich at idle (i think this may be why my idle is rough)
ideas?
(ask me questions to narrow things down)
Current Activity: Moderating
grkguy89 is offline
Old 07-29-2010, 06:24 PM   #2
dan-the-kid's Avatar
check out the IAC?
dan-the-kid is offline
Old 07-29-2010, 06:30 PM   #3
Greek Mod
grkguy89's Avatar
cleaned it and tried two other known good ones (i mean they others worked fine on the other cars)
made no diff
even tried another MAP sensor and made no diff (i might try a new one tomorrow)
grkguy89 is offline
Old 07-29-2010, 07:04 PM   #4
132417SAAB's Avatar
Is it the same tune? Could be over fueled now with the smaller displacement...
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 07-30-2010, 04:00 AM   #5
Greek Mod
grkguy89's Avatar
tried a stock ecu (stock turbo ecu) and my tuned ecu (matched to the hardware on the b204r; stage 4)
no difference
grkguy89 is offline
Old 07-30-2010, 06:39 AM   #6
132417SAAB's Avatar
start the car and unplug the iac if its bad you should notice an improvement
99 9-3 se
132417saab™©
AKA "numbers"
Old 07-30-2010, 07:32 AM   #7
Greek Mod
grkguy89's Avatar
if i unplug it it nearly stalls out, plug it back in and rpms shoot up for a second and then "idle" out
so its working, not necessarily working perfectly
grkguy89 is offline
Old 07-30-2010, 04:52 PM   #8
Greek Mod
grkguy89's Avatar
im gonna order a new iac mon from my shop to try out just to be on the safe side
any other ideas though?
grkguy89 is offline
Old 07-31-2010, 05:34 AM   #9
Nick Taliaferro
GenuineSaab's Avatar
The 2.3t broke?
Miss a ground wire on the intake manifold? IAC won't influence mixture.
Nicholas Taliaferro
GenuineSaab is offline
Old 07-31-2010, 05:58 AM   #10
Originally Posted by GenuineSaab View Post
The 2.3t broke?
Um... what would happen if you missed this ground wire?
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 07-31-2010, 06:12 AM   #11
Nick Taliaferro
There are power grounds and signal grounds. If you leave the signal ground floating this will bias the sensors. The power ground would make it hard for the injectors etc to function. Check the signal ground.
Nicholas Taliaferro
Old 07-31-2010, 07:16 AM   #12
Greek Mod
grkguy89's Avatar
The 2.3t broke?
nope, it didnt break
i reached a power ceiling on that setup and didnt want to invest anymore money since the b204 is much much easier to work with
in other word i had an itch for more (easy) power
ill check the grounds again to make sure
grkguy89 is offline
Old 07-31-2010, 07:36 AM   #13
Nick Taliaferro
You had a turbo manifold on it? Turbo cams would have helped some or different cam timing with stock 2.3i cams.
Nicholas Taliaferro
Old 08-01-2010, 07:59 AM   #14
Greek Mod
grkguy89's Avatar
i was very impressed with how the car performed plus i never had a chance to dyno it with the td04 on it but i would guess around the 230whp ball park
its just that i wanted to get into something that would cost "less" to upgrade to get it to 300hp
grkguy89 is offline
Old 08-01-2010, 08:44 AM   #15
OK, that might be the problem with my project car then. I know the engine was replaced at a certain point so that might be a definite possibility
Where would that ground be exactly Nick???
hkayssi is offline
Old 08-02-2010, 04:01 PM   #16
Greek Mod
grkguy89's Avatar
ok so here's the latest
my car still wont idle right
vac is at 11 in.Hg
on decel i barely hit 21 in.Hg so my car doesnt decel as it should when off the throttle
tech2 readings
at idle
tps is at 10.2%
timing at 3* (this is supposed to be at bout 10* right?)
and O2 reading all over the place
plugs look like things are running rich
grkguy89 is offline
Old 08-02-2010, 05:18 PM   #17
I think timing should be around 6-8 degrees.
Old 08-03-2010, 04:02 AM   #18
rattle
I removed the insolation from under my hood and added a blowoff valve at the same time. About that time i started getting a rattle noise only audible from the inside of the car. Im new to saabs and hope this is related any ideas what it might be?
live2record is offline
Old 08-03-2010, 04:06 AM   #19
Greek Mod
grkguy89's Avatar
try starting a new thread bout your problem
try just look around the engine bay for anything loose... maybe use a stethoscope to try and isolate it
[/thread jack]
back to my problems now :P
grkguy89 is offline
Old 08-03-2010, 04:09 AM   #20
thanks
sorry thanks i will do that
