Loud gear changes/clunks - The Saab Link Forums
Old 07-15-2010, 06:02 PM   #1
fiveiron9688's Avatar
When I put the transmission in my 900 into gear, or shift gears, I usually get a thunk sort of noise when the clutch grabs. I am going to overnight-bleed the clutch...hopefully that does something. It has done this for as long as I can remember. It has a new clutch master cylinder, slave cylinder, Viggen clutch kit, and now it has fresh MT-90 fluid too.
Anyone else have this problem, and know what I should do?
1998 900 SE turbo convertible
fiveiron9688 is offline
Old 07-15-2010, 09:56 PM   #2
Sleepy7666's Avatar
Swap in a AW50-40LE. Problem solved.
PS I touched your clutch.... of course your going to have issues dummy....
I lurk.
99 and 01 Saab 9-3
96 Escort LX
83 Yamaha XJ650 Maxim
Sleepy7666 is offline
Old 07-16-2010, 12:39 PM   #3
The Saab LB's Avatar
it could be your tranny mount
The Saab LB is offline
Old 07-16-2010, 01:40 PM   #4
It has a brand new GS poly trans mount and sport rear engine mount. I don't think those were the problem because the old mounts weren't in terrible shape. Plus this problem has been going on since before the mounts and clutch were replaced.
Could it be the one engine mount I haven't replaced? It seems unlikely to me, seeing as the others weren't falling apart...
Did the overnight bleeding last night, and about to go to Farm and Fleet to get some good wheel cleaner...should find out if that helped at all. The little amount of moving around in my driveway suggests that I still have a clunk when engaging gears...
Old 07-16-2010, 01:40 PM   #5
Yeah, how do the mounts look. I would completely remove it and give it a good looking over.
Does your shifter have excessive movement when you accel?
Old 07-16-2010, 03:05 PM   #6
The shifter can move around a bit when I'm in gear, but I've never really noticed it moving on its own while accelerating.
The overnight bleeding seems to have helped a bit...funny, because the clutch behavior isn't all that much different.
Tags
gears, loud, transmission
