P1625, ABS, TCS, Brake! /!\ light show - The Saab Link Forums
Old 12-20-2009, 02:49 PM   #1
codesplice's Avatar
Ladies and gents,
My 9-3 has been throwing a nice little light show for me lately. Started with the ABS, TCS, and BRAKE warning lights coming on and going back off within a few seconds. Everything else seemed okay. I had been driving through torrential rain when it first showed up, so I assumed maybe it was a fouled up wheelspeed sensor or something.
A week later, I got the ABS and BRAKE lights, along with the TCS OFF light. And the speedometer stopped working - dropped straight to zero, while my OBD-II scanner was still showing the speed fixed where it was - 88mph if you must know. It was a bit nerve-wracking, but TomTom knew how fast I was driving, and I didn't really care too much. Also, the problem would correct itself usually after driving for a while or letting the car sit for a while.
Finally, I got the same symptoms while driving, but also got a friendly CEL to go with it - the code is P1625, which I understand indicates a bus communications fail with the ABS/TCS module.
I'm guessing / hoping that the issue is an electrical problem in the wire bundle / connection to the ABS/TCS module - as the module seems to be rather pricey. To confirm this suspicion, I can sometimes get the trouble lights to clear by jiggling the wire bundle in the engine bay.
On a related/unrelated note, I've noticed that I sometime miss boost when the lights are on. This makes me sadface, and is the thing that motivates me to actually want to fix this
So how do you faithful Saabers fit in to this story? I'm glad you asked.
I could use some tips and/or pointers on troubleshooting and/or fixing this. Any wiring diagrams or other WIS-sourced information on that electrical system would be greatly appreciated.
Cheers,
John
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 12-20-2009, 05:41 PM   #2
Harvey's Autohaus's Avatar
Send the ABS Processor to this Guy
http://cgi.ebay.com/ebaymotors/Saab-...Q5fAccessories
HakbarSAABzzz
Harvey's Autohaus is offline
Old 12-20-2009, 06:15 PM   #3
codesplice's Avatar
^ sweet, I'll definitely look into that if I can't figure out anything else. Beats replacing the whole module for sure.
Thanks.
2007 9-5 2.3T Wagon
Old 12-20-2009, 06:25 PM   #4
Superwill00's Avatar
Send a message via AIM to Superwill00
Check your e-mail
00' Viggen
84' 900t Sold
War Eagle!
Superwill00 is offline
Old 12-20-2009, 06:49 PM   #5
Moreboost's Avatar
I sent the 9-5's abs module to BBA-Reman, great service, i sent it out on a monday got it back by friday. Fixed the light show
Moreboost is offline
Old 12-20-2009, 07:50 PM   #6
byastremski's Avatar
FUCK THAT.... save yourself some money... take your ABS TCS module out of the car... smear some diode electric grease in all the spring loaded connections... there will be 12 of them in a car with TCS and 8 in a car without.... they are just not making a good connection... ran into twice before... something saab should have done from the factory...
byastremski is offline
Old 12-21-2009, 04:16 AM   #7
codesplice's Avatar
That was the sort of advice I was looking for - thank you!
I'm gonna pull it out tonight and see what I can make of it.
2007 9-5 2.3T Wagon
Old 12-24-2009, 01:54 PM   #8
codesplice's Avatar
Well, I removed the ABS/TCS module, cleaned off what little dust and dirt I could see, smeared some di-electric grease on all the electrical connections, and reinstalled the module in the car. Went for a drive, and everything looked like it was working properly... until I started the car back up after parking for a few minutes.
ABS, TCS, and BRAKE warning lights are all back. Speedo is also dead again, and I am intermittently in limp home mode. And I still get that P1625 CEL every couple of starts. Looks like I will be sending it off to BBA next week.
2007 9-5 2.3T Wagon
Old 12-24-2009, 02:07 PM   #9
AUPilot09's Avatar
Send a message via AIM to AUPilot09
Yeah, but did you have to break off half an inch of ice to get INTO your car today?
Seriously, hope you can get that fixed man.
AUPilot09 is offline
Old 02-03-2010, 07:16 AM   #10
codesplice's Avatar
An update on this...
I'm lazy and haven't sent off the unit yet. I bought a Tech 2 recently, so I plugged that up to see if I could get any further in troubleshooting.
The Tech 2 reports absolutely no (0) communication with the ABS controller. None. Zero. Can't even get into that system to see what is at fault.
Intermittently, everything does work - particularly after the car sits for about 12 hours. This morning, for instance. Speedo worked, no ABS or TCS warning lights. Everything's groovy. I figured I would take advantage of that (while everything was operational) and plugged in the Tech 2 this morning.... all my lights came back, and it showed the communication failure again.
I may be wrong, but the fact that there is zero communication with the system (plus the intermittent nature of the problem) makes me want to think it's a wiring / connection issue rather than a failed module.
I would hate to send the module off to be remanufactured and it still not work due to a wiring issue (shorted ground somewhere, perhaps?).
Thoughts? Further troubleshooting suggestions?
2007 9-5 2.3T Wagon
Old 02-03-2010, 08:42 AM   #11
AUPilot09's Avatar
I've been having a quite similar problem, and I heard tell it was a wheel speed sensor. Check engine light came on one time, then disappeared. But I've had the speedo go dead, ABS, TCS/ESP, BRAKE failures etc a few times. Usually restarting clears it for a while, but it mostly happens when it's fuggin cold outside. I'm assuming there's some similar systems between your car and mine. Maybe, maybe not.
Old 02-03-2010, 09:30 AM   #12
Ero
Codesplice what makes you think its the wireing problem rather than the computer itself. As you know I'm having the same exact issue, and i'd much rather fix the computer and be done with it than try to track down a loose wire
'01 9-3 SE wheeeee
Ero is offline
Old 02-03-2010, 09:38 AM   #13
codesplice's Avatar
Me too.
I'm pretty much shooting in the dark, but I would rather confirm that it is the computer before I pay money to have that remanufactured. The fact that it works sometimes and doesn't others is what makes me second-guess myself here. If the computer were actually fried, I don't think it would work at all.
Again, I'm not exactly a supersleuth mechanic, but I am learning a lot about the system as I try to track down each potential problem. So whether or not I'm going about this the right way, I'm learning - so I win.
I think I'm going to swap the ABS/TCS modules between my 9-3s this weekend and see if there's any change there.
2007 9-5 2.3T Wagon
Old 02-03-2010, 09:53 AM   #14
Ero
please let me know how it goes, as I'm of the same mindset, i'd rather not pay 55 bux if the computer is not the problem.
Incidentally, rather than BBA, you can look here
http://cgi.ebay.com/ebaymotors/SAAB-...#ht_3912wt_998
much cheaper.
'01 9-3 SE wheeeee
Ero is offline
Old 02-03-2010, 10:28 AM   #15
spgproject's Avatar
the abs modules can definitly be intermittent.
-Sir William Lyons
spgproject is offline
Old 02-03-2010, 10:37 AM   #16
Ero
would you suggest getting it rebuilt anyway because if it's not at fault now it will be sooner or later?
'01 9-3 SE wheeeee
Ero is offline
Old 02-03-2010, 11:29 AM   #17
lms
Originally Posted by codesplice View Post
Me too.
Dont't forget to marry it to the car or the cel will never go away after the swap.
lms is offline
Old 02-03-2010, 12:11 PM   #18
codesplice's Avatar
*nod* Should be a good experience to get me more familiar with the workings of the Tech 2.
2007 9-5 2.3T Wagon
Old 05-28-2011, 01:31 AM   #19
P1625 error is part of the solution coming from the engine wiring harness worn over time ABS-TCS-BRAKE lights illuminated the right side engine cover oynatınca cables into the passenger cabin lights turn off.
axlpc is offline
Old 05-28-2011, 01:32 AM   #20
P1625 error is part of the solution coming from the engine wiring harness worn over time ABS-TCS-BRAKE lights illuminated the right side engine cover cables move the lamps will go out into the passenger cabin.
axlpc is offline
