Clunk from front suspension/how to tighten top strut nut - The Saab Link Forums
Old 08-13-2009, 12:27 PM   #1
dsaabm's Avatar
So when going over bumps and making a right hand turn, I get a clunk/baseball hitting left side wheel well area/firewall sound. I am thinking that the top strut nut is loose. How would I tighten it while it is installed in the car? Any other ideas?
Car is a 2000 with 50k miles.
Thanks
dsaabm is offline
Old 08-13-2009, 12:45 PM   #2
nowhereman's Avatar
could you be hitting the bump stops?
2008 9-3 SS: Stg 1
nowhereman is offline
Old 08-13-2009, 12:51 PM   #3
Deez Nutz
Palmer's Avatar
Sounds like a strut bearing to me, or maybe a broken spring?
Neither can be adjusted/tightened.
S55/LC100/KL
Palmer is offline
Old 08-13-2009, 01:42 PM   #4
Try removing the wheel, and using a bit set of channel locks.
Old 08-13-2009, 01:56 PM   #5
dsaabm's Avatar
I don't think I am hitting the stops, as these are very mild bumps, and I have heard this noise when turning on smooth pavement as well. I suppose if I had a busted spring I would be hitting the bumps stops though. Mabye its a busted spring?
Tweek, what wheel are you talking about? You mean the nut?
dsaabm is offline
Old 08-13-2009, 02:02 PM   #6
BurnsSide42's Avatar
Broken Spring or Spring Off it's seat. (If not a loose or worn strut mount)
Check Ball Joint too....
Check out
for your repair needs
BurnsSide42 is offline
Old 08-14-2009, 06:35 AM   #7
lms
Like tweeks states, pull wheel and check the gland nut which holds the insert in the strut. Could be a few things like stated above, try easiest first.
lms is offline
Old 08-14-2009, 08:24 AM   #8
Thanks
Whatever side you think the nut is loose. (my guess Left) One each corner of your saab very close to the suspension is a wheel. Remove it to get a closer look at the clunking. And I meant big channel locks, not bit. On
Old 08-15-2009, 07:19 AM   #9
dsaabm's Avatar
Thanks for the help guys, and sorry tweek, didn't mean for my response to come across as it did.
I found the problem, the strut is banging against the shock at the point where the shock insert is screwed into the strut housing. If I push up on the base of the strut I can see it hit the shock and make the noise.
How do I fix this? By turning the gland nut where the shock is screwed into the housing? Thanks again
dsaabm is offline
Old 08-15-2009, 10:27 AM   #10
lms
Yes, if I'm understanding the question.
lms is offline
Old 08-15-2009, 10:36 AM   #11
dsaabm's Avatar
Thanks for the help lms. Any tips on how to tighten it, I tried with a pipe wrench, put no dice. I am thinking about letting it soak in liquid wrench then trying again with channel locks/pipewrench?
dsaabm is offline
