Washer nozzles - The Saab Link Forums
Old 07-15-2008, 06:43 AM   #1
Fathead's Avatar
Washer nozzles
So I recently noticed that I had ran my tank dry of washer fluid. I bought a new bottle, filled up the reservoir and figured everything was cool. I went to wipe off my windshield using it and nothing came out. Tried again, holding the lever for about 10 seconds, nothing. Then I notice that there is spray coming from the front of my car and find out that my headlight washers are working perfectly. I get under the hood and do some poking around and find 2 hoses unhooked (prolly from when I was installing my boost gauge last week). I hook them back up, try again and still nothing. I traced every fluid line I possibly could, even unhooked the line running to the hood and pulled the lever to make sure it was squirting and it sprayed all over the wall of my garage. Hooked it back up, tried again and still nothing. As far as I can tell, all my lines are hooked up right, nothing is kinked or blocked. The pump obviously works and I took a needle and gently poked into the nozzle holes themselves to make sure they weren't clogged with dirt. Any ideas?
Fathead is offline
Old 07-15-2008, 12:27 PM   #2
JustRunIt's Avatar
You can try unhookng the check valve from under the first nozzle, and plugging the supply line directly to the nozzle. if it works, you need a new check valve, If nothing comes out, you can try blowing compressed air throught the nozzle as you might have crud in the nozzle body. you may verry well end up needing new nozzles if you can't rule out the check valves. nozzles should be $17 or less and the valve should be around $5
hope this helps.
I'm good at dealing with people!
Can't you understand that?
WHAT THE HELL IS WRONG WITH YOU PEOPLE?
JustRunIt is offline
Old 07-17-2008, 11:09 PM   #3
Boosted Coops's Avatar
yea, i had issues with the one way valves in the system. replaced them all and everything worked fine. but ya, i had the same problem where i ran it dry. so after i replaced the valves, i took the old ones appart and there was just dried wiper fluid gumming them up, so i probably could just cleaned them out and they woulda worked fine. but they are like $3ea. on eeuroparts.com i think, so just order some extra stuff and shipping is free if you have a $40 order or more.
Your signature was too big.
480x70px or smaller please.
Boosted Coops is offline
Old 09-24-2008, 12:10 PM   #4
Fathead's Avatar
I ended up popping them out and taking a razor blade to the end of the valves, popped them off and found all that gooey crusty nastiness gumming up the springs and such. I wiped them off as best I could with some sturdy paper towels and ArmorAll windshield and window cleaner. I used the razor blade to scrape the rest of it off. Popped the caps back on the valves, reinstalled them and they work (mostly) like a charm. The passenger side one works great but the driver side valve only works after pulling the lever a couple times. Minor gripe really.
Fathead is offline
