Hard/Rough Start Fixed – Not Your Typical Culprit - The Saab Link Forums
Old 02-11-2008, 01:32 PM   #1
ERP
ERP's Avatar
Send a message via AIM to ERP
This problem came up after my 2.3L swap, but it could happen to anyone with a NG900/9-3. I had a hard time starting the engine and it took me a while to figure out. Cold starts would take 3-5 attempts to get the engine to catch and idle. It would idle high then come down to 1000 rpm after a few seconds. Power was down for the first 30-60 seconds, then the engine would pick up and drive great. Gas mileage was good too, only down a few points from average. But what made this different than typical hard starts was that it was worse when the engine was hot. It would take even more cranks to get the engine to start. I tried all the standard fixes first. I cleaned the IAC, I swapped in a spare Fuel Pressure Regulator, I swapped in a spare Throttle Position Sensor, I swapped in a spare Crank Positions Sensor, I changed the fuel pump and check valves(upgraded to the Walbro) and I replaced my alternator (old one was going out and my battery was less than a year old). Nothing made any difference.
I swapped in a crushed FPR and it did help a little, but did not fix the hard starts. I pulled the vacuum line from the FPR and it richened up idle and helped the starts, but was dangerously lean under boost, don't try this without a wideband O2 sensor. I also re-flashed my ECU since I was running a 2.0L on a 2.3L engine. I could see on my wide-band that my air/fuel was lean 16-17 at idle, but nice and rich under boost. For two months my Saab was hard to start but I never saw any check engine light.
The solution appeared when I hooked up my laptop to the OBD2 port and checked out all the sensors. The coolant temp sensor showed -40F. This is parked in the garage and there was no change in temp after a few minutes of idling. At first I thought it was just my reader having a problem interpreting the ECU, since my coolant gauge was working fine and I replaced the coolant sensor about a year ago. Then I talked to JZW and he reminded me there are two coolant sensors. I could have hit my head on the wall. Two months of hard starts and all the time I spent trying to fix it and my ECU coolant sensor was simply unplugged. I plugged it in and the engine starts great now. So if you are having problems starting cold and hot, check the coolant sensor in the intake manifold.
2005 9-2x Aero Stg 2
1996 900 'Aero' 2.3t Sold -
ERP is offline
Old 02-11-2008, 01:39 PM   #2
Moonracer's Avatar
didn't it set a CEL with that unplugged? It should have.
Moonracer is offline
Old 02-11-2008, 01:44 PM   #3
ERP
ERP's Avatar
Nope, never got a CEL though all of it. I wish I had, it would have made it easier to figure out.
ERP is offline
Old 02-11-2008, 01:47 PM   #4
Moonracer's Avatar
strange?
Old 02-11-2008, 03:12 PM   #5
DeLorean's Avatar
you won't get a CEL from an un plugged NCT sensor, the ECU just assumes the value of 0 ohms resistance is correct (and that it's -40 outside). If you are having running issues, checking all the sensor outputs would be the first thing I'd check. on the Megatune screen, you can pull up the realtime display and check all the sensor outputs at a glance.
DeLorean is offline
Old 02-11-2008, 03:17 PM   #6
NickTurbo900's Avatar
Drool. I would like to have this ability. Can someone point me in the direction of the required hardware/software???
Congrats on the fix ERP. Only a swedish car could believe it was -40F for days on end.
NickTurbo900 is offline
Old 02-11-2008, 03:19 PM   #7
drewz airflow se's Avatar
I just wish my car was OBD2
^CLICK ME^
drewz airflow se is offline
Old 02-11-2008, 03:41 PM   #8
HNNLIC
Blaque's Avatar
This is really informative. I've been dealing with the same issue for quite a while. Good info Eric.
Blaque is offline
Old 02-11-2008, 04:16 PM   #9
ERP
ERP's Avatar
Yea, but even a Swedish car should realize that after 2 hours of driving the coolant temp should get above -40F.
The hardware/software that I used to hook up to my OBD2 was Digimoto, http://www.digimoto.com/shop/ It comes in handy for sensor reading, CELs and turning them off, and data logging.
ERP is offline
Old 02-11-2008, 04:20 PM   #10
OMG. Eric Thank you. Thank you. Thank you.
This is wunderful. Thank you!
Thank you so much! I cannot believe how inexpensive this is. Sorry guys but my FS posts will continue to fill up the forum til I have this amazing tool in my hands!
