Parts I have replaced on my Saab - The Saab Link Forums
Old 11-25-2007, 09:43 AM   #1
ERP
ERP's Avatar
Send a message via AIM to ERP
I though it could be helpful to put together a list of Saab parts that I have replaced since I purchased the vehicle nearly 7 years ago. Despite its length my Saab has had relatively few parts that simply failed, most I believe have failed either due to above average abuse, such as the engine and tranny, or because I broke the part during disassembly. And nearly half the list was replaced because of performance reasons rather than a failure.
I have not included common wear or replacement parts such as filters and sparkplugs. Also I did not included extra modifications such as gauges and tried to limit the list to parts that have failed or been upgraded.
Part:__________________Replacement Type:_________Reason:
2.0 Engine......................Used 2.3L...........................Oil Rings Leaking
Manual Tranny................Used 9-3 Tranny..................Destroyed Syncros
Cylinder Head.................Re-Machined.......................Warped
2 Valves 8 Guides............New............................. .....Broken & Worn
Clutch + PP....................New, Viggen.......................Broke
3 Clutch Cables...............New.......................... ........Broke
Cable Clutch Pedal...........New, Hydraulic Pedal............Tired of replacing cables
Power Steering Bracket....Used..................................B roke
Optima Battery...............New......................... ..........Failed
Fuel Pump......................New, Walbro.......................Failing
CV Joint........................New Unit............................Cracked Joint and Boot
DI................................New Unit.............................Misfire
Timing Chain & Guides......New................................... Preventive, Engine was out
AIC..............................Used............. ......................It Failed
Coolant Hose.................New.......................... ..........Burst
Coolant Temp Sensor......New................................... .Broke it
Coolant Cap..................New.......................... ..........Leaked
AC Fill Valve..................New........................ ............Failed
Hood Badge..................New........................ ............Wore Out
Windshield....................New................. ...................Cracked
Windshield Reservoir.......Used.............................. .....Broke it
Oil Dip Stick..................Used....................... ............Broke it
Throttle Body................Used.......................... .........Broke it
Throttle Position Sensor...Used..................................It Failed
Tie Rod End...................New......................... ..........Broke it
Headlight Lens...............New............................ .......Broke it
Headlight Switch............Used............................ ......Broke it
Drilled Brake Rotors.........New................................ ...Wore Out
ECU.............................Re-programmed....................Performance
Brake Lines...................New, Stainless......................Performance
Intake.........................Cone Filter...........................Performance
Intercooler (Twice)........Viggen & Bar + Plate..............Performance
Intake Piping.................New, Stainless.....................Performance
BOV.............................New............... ...................Performance
Flywheel.......................New, Aluminum....................Performance
Turbo...........................Used, TDO4........................Performance
Exhaust & Cat................New............................ ......Performance
Springs.........................New............... ...................Performance
Various Bushings.............New.......................... .......Performance
Rear Roll Bar..................New.......................... ........Performance
Shifter..........................New.............. ...................Performance
Engine Mount.................New, Poly..........................Performance
Thermostat....................New, 82C..........................Performance
Sound System................New......................... ........Quality
Interior Door Handles.......Used, Chrome.....................Aesthetics
Grille.............................Used, 9-3.........................Aesthetics
Bumpers........................Used, Viggen.....................Aesthetics
Wheels..........................New............... .................Aesthetics & Performance
2005 9-2x Aero Stg 2
1996 900 'Aero' 2.3t Sold -
ERP is offline
Old 11-25-2007, 10:36 AM   #2
drewz airflow se's Avatar
nice list
^CLICK ME^
drewz airflow se is offline
Old 11-25-2007, 06:27 PM   #3
Send a message via AIM to aero93
have you ever changed the axles?
aero93 is offline
Old 11-26-2007, 06:11 AM   #4
ERP
ERP's Avatar
Nope, just the passenger CV joint.
ERP is offline
Old 11-26-2007, 08:35 AM   #5
StX221's Avatar
Won't even contribute to this thread. It might make me cry
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 11-26-2007, 09:12 AM   #6
SAAB9-3USA's Avatar
thread jack/
how hard is it to warp the head
i recently broke and end tank on my radiator and my car got about 3/4 hot
could i have done serious damnge.
SAAB9-3USA is offline
Old 11-26-2007, 09:27 AM   #7
ERP
ERP's Avatar
It is difficult to warp a head, I doubt that you damaged yours with slight overheating. You really have to try to warp a head. I blew a hose in the mountains on the way to a ski race and had to continue to drive and stop to cool down the engine, it was 8 degrees F out. But even that did not significantly warp the head. When I had the head machined it was barely out of tolerance. The leak was caused by a blow-out in part of the head gasket.
ERP is offline
Old 11-26-2007, 11:21 AM   #8
Editor
I've never thought about this.
-Shifter assembly (used)
-Brakelight switch (GM part - worn out)
-Bulbs (All over car, typically headlights, regardless of brand)
-Linkage bushing (worn out, broken)
-Thermostat (stuck open)
-Ignition module (misfire due to poor insulation)
-Turbocharger (blowing oil, replaced with stock used T25)
-Wheels (Vikings are uglyyyy)
-Front pads (Akebono ceramic)
-Grille (aesthetic)
-Flexpipe (rotten through)
-Mats (stained, falling apart)
-Upper idler pulley (shattered 200 miles away in Indiana)
-Gas cap (poor vacuum, I think? I don't remember)
-Battery
-Throttle body cover (ruined the first one)
-Turbo heat shield (Not equipped on NG900s)
As far as the engine goes, off the top of my head:
-Timing chain and guides
-All gaskets, seals and o-rings
-Oil pump gears and cover
-Timing Cover
-PVC valve
-Most vacuum hoses
-All coolant hoses
-Oil pressure sensor
This doesn't include some of the other stuff I've ghetto rigged - for example, there are two metal hoses beneath the exhaust manifold - I had to pull them both to braise one of them, it had a pin-sized hole that needed to be patched.
Edit: Wow, re-read. These cars are a plague if they're not properly taken care of. Mine's even been garaged every winter of its life and I still dealt with all of this. Previous owner must've beat the shit out of it.
This is a lot of stuff for two and a half years, especially considering the car hasn't been driven the past year.
Les Bouquins is offline
Old 11-26-2007, 01:02 PM   #9
Send a message via AIM to mlemorie Send a message via MSN to mlemorie
Lets see here:
Heater hoses..........new hoses..........split hose
Brake calipers.........new units (4).......all siezed up at one time or another
Brake rotors/pads....new...................preventative maintenance when calipers went
Ball joint/control arm...new................worn balljoint
Wheel bearing...........new.................worn out death growl
Upper Idler...............new..................siezed up and broke between home and school
Fender....................used.................alm ost torn off when wheel fell off
Inner fender.............used.................^^^^^^^^
Clutch cable.............new..................snapped in school parking lot
Tires.................used/new................1 flat, 1 shredded when it fell off, then all 4 replaced with new
Various lights............new.................burn outs
Valve cover gasket....new..................leaky
Radiator fan..............used.................bearings locked up and fried motor
Washer fluid pump.....new..................would wash rear window but not front
Fuel pump................new..................died in the middlle of moving to new apartment
Serpentine belt.........new...................replaced with pulley
Battery...................new...................wo uldnt hold charge
Antenna mast..........new....................worm gear broke
ICE module..............new....................old one quit working
I think thats everything, not counting plugs, oil, etc. Ive had this car since august/september of 05
mlemorie is offline
