stage 3 and there goes the motor first night - The Saab Link Forums
Old 11-02-2007, 09:52 PM   #1
Send a message via AIM to aero93
okay so i just put in jak stoll stage 3 ecu my current mods are td04 and x flow intercooler and the ecu, went out and took it for a ride 4 pulls in 4th from 50 to 90 all solid power turbo would spool past the red, i go out and dirve a little bit around long island and down to dpa but did not race the car, i stop at a light and it turns green i slowly go and then shift to second and all of a suden boom and no power pull over check around turns out its a intercooler hose rip apart my car at 2 in the morning and put it all back together it turns out it boosts fine, on my way home im cruising just still trying to get the ecu adjusted and im doing a 50mph pull when all of a sudden loss of power and the car starts to shake and ratle when im on the gas, pull over check the motor everything seems fine get back in starts fine but then it starts to shake softly again, get to school and i take out the di to see if i shot oil on my plugs turns out their okay , disconect the battery thinking maybe its the ecu , and then i get back in and drive it again this time im driving and do a slow pull and my check engine starts to blink and when i come to a stop it stays on and i hear a murrmuur from the engine and i think i might have blown the motor, im not sure how or what it would sound like but i have no idea and the car shakes under throttle ... please help i need it asap !! what could it be? why would it do this ? pre requisit is a turbo back exhaust but why would the lack of one blow my motor after asking many people would it they insited that it would run rich and not lean? i need help bad anything would be greatly appreciated thanks
aero93 is offline
Old 11-02-2007, 10:01 PM   #2
Deez Nutz
Palmer's Avatar
You have a boost leak.
Your tune exposed the weaknesses in your car.
Before the grammar natzis rip you a new one, I would recommend that you make sure your car is in 100% shape before slapping a tune on it.
S55/LC100/KL
Palmer is offline
Old 11-02-2007, 10:04 PM   #3
a boost leak ? but it murmers no matter what even when it idles now and i cant figure it out and i checked all my line and cant to see any problems in fact i replaced them a few days ago with new silicone lines, the car will studder while on its way up to climbing boost ??
aero93 is offline
Old 11-02-2007, 10:11 PM   #4
saabkid37's Avatar
what year is the car.
saabkid37 is offline
Old 11-02-2007, 10:22 PM   #5
its a 99 9-3 t5
aero93 is offline
Old 11-02-2007, 11:35 PM   #6
HNNLIC
Blaque's Avatar
Time to pull codes and do a compression check.
Blaque is offline
Old 11-02-2007, 11:43 PM   #7
i was relieved when you said IC hose blew off... dunno about the rest
Saaboy is offline
Old 11-03-2007, 04:22 AM   #8
I work in farmingdale and live in Lynbrook. I am an expert at this point on boost leaks lol. Let me know if you want to meet up.
Jameson is offline
Old 11-03-2007, 05:10 AM   #9
NahumCC's Avatar
Flashing CEL was for misfires. 1.) Get new plugs 2.) Get new silicone vac lines
If there is still a problem after that continue trouble shooting and let us know what its doing.
As to the turbo back. If your system is too small you'll have high EGT's due to excessive back pressure which can cause other problems. Your DI if its old may also be dieing now.
2013 FR-S
NahumCC is offline
Old 11-03-2007, 05:14 AM   #10
NickTurbo900's Avatar
Oh no dude your car is ruined! I'll give you a $800 for it!
HAhah no seriously ^^^^ what they all said... then get back to us all!
NickTurbo900 is offline
Old 11-03-2007, 06:19 AM   #11
CooperS7777's Avatar
Boost leak (turbo related anyway) doesnt usually have that kind of effect on a T5 car, though its hit or miss. It could certainly be a vacuum line - thats where I would start.
CooperS7777 is offline
Old 11-03-2007, 07:10 AM   #12
saabkid37's Avatar
yeah but a t5 car can basically run with no connection between the ic and tb vac leaks really wont make it noisy like that. do you have abost gauge?
Old 11-03-2007, 07:27 AM   #13
mcrowley's Avatar
Yeah, boost leaks won't wreak havoc on a T5 car like a T7...still not good to have one though.
I'd say your problem is ignition. Get a fresh set of plugs, try another di.
DEFINITELY don't run it hard for very long with that stock exhaust either.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 11-03-2007, 07:30 AM   #14
fretrunner9000's Avatar
Send a message via AIM to fretrunner9000 Send a message via MSN to fretrunner9000
could also be your pvc seal is gone or just got completely blown off.
That happened to me when i first went stage 3 in the 9k and that fits all the symptoms low boost, shuddering, ok under a little bit of acceleration but shaky and rough under more then a few pounds. Id check there as well.
2003 93 Linear Stage 2
fretrunner9000 is offline
Old 11-03-2007, 07:47 AM   #15
saabkid37's Avatar
yeah but your later shaking/vibration issue was a spun bearing lol.
edit: see if you can find someone to smoke test the car.
Old 11-03-2007, 09:07 AM   #16
Trollerator
abdukted1456's Avatar
can we try and not use F bombs in thread titles please. Me fixey.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 11-03-2007, 09:10 AM   #17
haha that was 2 years later!
Old 11-03-2007, 09:10 AM   #18
moose's Avatar
ya guys what the fuck.
this is some crazy stuff i'm glad nothing crazy happened when i put my JSP stg. 3 in, and still nothings happened yet.
undercover Moderator
Stg. no go
moose is offline
Old 11-03-2007, 09:28 AM   #19
griffen nut's Avatar
Send a message via AIM to griffen nut
Sounds like the car is just missing REALLY bad
Probably a simple fix...DI, plugs, etc like every1 said.
griffen nut is offline
Old 11-03-2007, 11:49 AM   #20
well after all the advice i changed the plugs and put electric goo on it and it runs fine now, pep boys didnt have ngk irridium so i got another brand still platinum and it runs fine thank god.. but the boost isnt climbing as high before it would go past the red and fall back but now it just climbs to the red and stops is this a good or bad thing ? thank you guys soo much for all the help i really appreciate it all and awsome advice thanks again !
aero93 is offline
