Seat Heat? - The Saab Link Forums
Old 10-26-2007, 04:00 PM   #1
nowhereman's Avatar
Seat Heat?
So i have a 1997 900SE. Leather etc. My seat heater no longer works. it lights up the button on the console but yeah not heat. Passenger side will roast you out of the seat. with winter approaching i want to get my heater to work. what is the procedure and is it a DIY? can i just swap the heater from passenger to driver? if so is it easy? or might there be a connection i should check first?
2008 9-3 SS: Stg 1
nowhereman is offline
Old 10-26-2007, 04:17 PM   #2
drewz airflow se's Avatar
mine is shot too on the driver side
^CLICK ME^
drewz airflow se is offline
Old 10-26-2007, 04:26 PM   #3
soccerrplyr's Avatar
you can but you'll need to take off your seat skins, peel off the foam that is adhesived to the seat padding that contains the seat heating wirer element, cut the power wires, and reattch to your drivers side wire.
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 10-30-2007, 04:56 AM   #4
nowhereman's Avatar
so what is the quickest and easiest way for that to be done. my butt is cold. it was 30 last night when i got out of work...
2008 9-3 SS: Stg 1
Old 10-30-2007, 05:23 AM   #5
Curlymurt's Avatar
Purchase:
http://www.eeuroparts.com/productdet...ts=1&code=4697
Grab some tools, take a day, and start pulling the bottom of your seat apart. I would imagine it will go back together fairly nicely if you don't break anything.
Honestly, I think the only thing you need to do is undo the hook wires at the backside of the bottom portion of the seat. Pull that back a bit and you might have to pull back the sides of the seat also in order to expost the heating pad. But, I've never done it so don't take my word for it. Wait a month and I might be able to tell you.
Updated 04/02/2010:
'04 9-3 Aero
Curlymurt is offline
Old 10-30-2007, 05:26 AM   #6
Champ's Avatar
Make sure first you have not blown any fuses, and then check to see that all the connectors around and under the seat are connected. I believe there should be a connector between the seat bottom and seat back, if you have a back pad.
Champ is offline
Old 10-30-2007, 05:49 AM   #7
CooperS7777's Avatar
Yep, the passenger side on my NG is out, the GF complains now but my ass is toasty warm so there is really no need for me to worry about it!
CooperS7777 is offline
Old 10-30-2007, 06:13 AM   #8
yea its either the switch or the seat heater. If the passenger seat works, swap the switches an see if the problem travels. Otherwise the coil usually breaks at the bolsters on the sides of the seat.
Stage: power back on the road
fieldsc is offline
Old 11-01-2007, 09:11 AM   #9
nowhereman's Avatar
Thanks i will check this out this weekend...
Yeah mine is the opposite. the GF gets toasted and i freeze. seeing as it is my car and i am the person that gets in it in the cold i think i should have the heat...
2008 9-3 SS: Stg 1
Old 11-01-2007, 08:37 PM   #10
guru's Avatar
If you end up fixing it this weekend, I want to watch, I'll bring beer. Must learn how to do this for when mine breaks in two months.
guru is offline
Old 11-02-2007, 04:44 AM   #11
nowhereman's Avatar
i will be doing this on the weekend also cleaning GFs car as well.. what kind of beer will be brought? lol
2008 9-3 SS: Stg 1
Old 11-02-2007, 04:57 AM   #12
NickTurbo900's Avatar
Originally Posted by Curlymurt View Post
120$? My butt can freeze.
or:
Open up the existing heating pad, find the breaks in the coil. Solder in a new element of the same gauge, look for any weakspots to prevent it from happening again too soon.
NickTurbo900 is offline
Old 11-02-2007, 05:08 AM   #13
nowhereman's Avatar
or:
Now that is more my idea.. exactly what i was looking to do as 120 is way too much.. or just swap pads from passanger to driver. hell maybe add a back pad if i dont have one.. lol
2008 9-3 SS: Stg 1
Old 11-02-2007, 05:28 AM   #14
you dont even need new wire, just cut off the shorted portions and pull a some of the wire out of its zig-zag formation, solder and you are good to go.
fieldsc is offline
Old 11-02-2007, 06:22 AM   #15
nowhereman's Avatar
nice to know. all i need now is a soldering iron..
time to visit the parents i do think...
2008 9-3 SS: Stg 1
Old 11-02-2007, 06:24 AM   #16
Curlymurt's Avatar
or:
Fair enough, but that's why I do freeze... I didn't even know what the heating pad looked like really. I might try that...
Updated 04/02/2010:
'04 9-3 Aero
Old 11-02-2007, 06:27 AM   #17
http://quasimotors.com/heated_seat_repair.htm
thats for a 9000. Same general principle for a ng, bolts might be different sizes, seat will be slightly different, etc. Read that an you can tackle it.
fieldsc is offline
Old 11-04-2007, 12:55 PM   #18
Makeyousaab's Avatar
nowhereman, i've got a spare seat from a 94 Ng. if its not hard to take out i'll sell you mine for ALOT less than 120
~Dave
Makeyousaab is offline
