T5/T7 AC compressor bypass. Short belt info. - The Saab Link Forums
Old 10-07-2007, 10:05 PM   #1
aireeca's Avatar
Exclamation T5/T7 AC compressor bypass. Short belt info.
T5 info is at the bottom of the thread.
Here's how to short belt your T7 when your AC compressor decides to begin its death rattle:
(Tweek, please embellish this so it doesn't sound so retarded)
1. Read the Saablink search results for "short belt," disregard anything that mentions a 6pk 2345mm belt size. That's the size already on the car.
2. Open your owner's manual to the specifications section.
3. Buy 1805 mm belt/71.06 inch belt.
4. Ask Tweek nicely if he'll do the work.
5. If no Tweek is available, then unbolt the strut brace and jack up front right passenger's side wheel.
6. Remove the wheel and remove the panel in the middle of the wheel well.
7. (Do something I didn't catch to make it easier to remove belt.)
8. Remove belt. Struggle.
9. Keep trying to remove belt and then loosen mounting bolts on air box to make it easier to remove belt. Loosen clamps on the crinkle hose and remove the hose.
10. Thread new belt following diagram in specifications section of your owner's manual but bypass the lowest right pulley, which is the AC compressor.
11. Get ready to retension the belt. If a Tweek is doing the install, call DeLorean and PaulH. to come help when Aireeca freaks out about potentially saucing the car by pulling too hard during the manuever.
12. Reassemble air box, wheel, brace.
13. Start the car up and, ahem, "see what happens."
14. If Tweek is involved, buy him a Gatorade and a water because that's all he'll take in return.
15. If no Tweek is involved, buy yourself a Gatorade and prepare to roll in your AC-less, happier 9-3. Woot!
Biggest important thing to remember:
The length of the belt that goes around the AC compressor is 2345mm which is NOT the length for the short belt delete. The real belt sized needed for this is 1805mm/71.06 inches.
Belt Part Numbers? Oh yeah, I got 'em...
Gatorback 4060710
Duralast 884510
Saab 4961058
JUST IN FROM TWEEK!!!
Late NG900s and early OG9-3s take a 1815 mm belt for the short belt/AC bypass.
Last edited by aireeca; 03-13-2010 at 08:37 PM. Reason: Let's bump those part numbers up, Up, UP!!!
aireeca is offline
Old 10-07-2007, 10:08 PM   #2
NahumCC's Avatar
Edit: If no tweek is around pester aireeca till she gives you tsl vcard (or whatever it is) of emergency contact info for local tsl assistance should you need it .
2013 FR-S
NahumCC is offline
Old 10-07-2007, 10:15 PM   #3
StX221's Avatar
You might also want to unplug the one connecter that goes to the compressor.
Especially if you have ACC. that way you dont try and get the clutch to lockup when it cant. To me, I would just feel a little bit better about doing it.
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 10-07-2007, 10:24 PM   #4
aireeca's Avatar
Description of connector? Directions on how to find said connector? I think there's a red wire down there? Do I cut it or the black wire to defuse the bomb, I mean ACC?
aireeca is offline
Old 10-08-2007, 04:39 AM   #5
codesplice's Avatar
Now just go on and remove the A/C. You don't really need it, and the compressor + condenser + plumbing weighs probably 15-20 lb - not to mention the reduced load on the engine.
Do it! Do it!
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 10-08-2007, 05:02 AM   #6
NahumCC's Avatar
Beau she's already bypassed the compressor therefore there is no load on the engine anymore............other then carrying an extra 20 lbs.
2013 FR-S
NahumCC is offline
Old 10-08-2007, 05:04 AM   #7
codesplice's Avatar
Hush. It's morning.
*sips third Dew of the last hour*
Also, "Electric Boogaloo" is the name of a pretty sweet Five Iron Frenzy album. Good times.
2007 9-5 2.3T Wagon
Old 10-08-2007, 07:09 AM   #8
StX221's Avatar
Well, it might be hard to find, but if you look all around, there is only one wire that comes off the compressor. somewhere up the line is some kind of connector (you shouldnt have to cut anything). It will probably be behind the passenger side headlamp somewhere.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 10-08-2007, 07:13 AM   #9
codesplice's Avatar
Is there perhaps a fuse for the ACC system? That might be easier than disconnecting the compressor.
2007 9-5 2.3T Wagon
Old 10-08-2007, 07:21 AM   #10
StX221's Avatar
Thats true, Good call splice. Check in the engine bay fuse box, there should be a fuse for the A/C compressor. I know there is one in the 9-5 fuse box, and I would assume that it would be the same in a 9-3 fuse box.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 10-08-2007, 07:51 AM   #11
+1...
2345 is the correct belt for short belt mod on a T5 NG900/9-3 (B204 engine), but not a T7 B205
My apologies for getting bad info to you.....
Old 10-08-2007, 07:58 AM   #12
aireeca's Avatar
No problem. It was easy enough to figure out once Tweek had pulled the old belt and I could see the length on it (the belt itself is still fairly new and happy). Luckily, it was fixable with just another trip down to Autozone and watching the desk guy type...very...slowly...the millimeters...into...the...conversion...program... on...his...computer..........Ack.
(P.S. Reading the driver's manual also was a BIG help. Who knew?)
aireeca is offline
Old 10-08-2007, 09:26 AM   #13
aireeca's Avatar
Oh, while I've got a Duralast belt or some such on the car right now, here is the Saab part number for the 1805 belt: 4961058.
aireeca is offline
Old 10-08-2007, 12:52 PM   #14
Yes, I seem to have trouble comunicating with car parts people. Ironic I know.
I told them pk1805. They said they had no such belt in the cross reference. After we convert over to inches, magically one shows up. With the 6pk 1805 written right on the box.
This will also work on 900s if you do middle pulley delet (short belt) and want to bypass the AC.
T7 cars are also a huge pita to work on.
Old 10-08-2007, 12:59 PM   #15
drewz airflow se's Avatar
:nods head yes violently:
^CLICK ME^
drewz airflow se is offline
Old 10-08-2007, 01:01 PM   #16
aireeca's Avatar
Well, I thought you had been gentle with Harald. However, he seemed reluctant to sit down today.....
aireeca is offline
Old 10-08-2007, 01:03 PM   #17
Aireeca, have you cleaned the engine bay yet? I used alcohol prep pads on my hands today and they are still dirty.
Old 10-08-2007, 01:06 PM   #18
aireeca's Avatar
Indeed. I hosed down the engine bay this morning as I was doing some post Saabtoberfest maintenance. Looks a lot better. Also, you taking a lot of the dirt away on your hands seemed to help, too.
aireeca is offline
Old 10-08-2007, 04:06 PM   #19
kalvinr11's Avatar
That's exactly what I thought when I read the title....Five Iron Frenzy 2: Electric Boogaloo. It's actually in the CD player in my car. Weird.
[/FIF content]
Doing belts on Saabs has never been my favorite thing. Especially the post '99 9-3s and all the 9-5s. The one on my Viggen isn't too bad.
-Mike
'99 Viggen with 205k
Status: Mostly OK and studded winter tires
kalvinr11 is offline
Old 02-01-2008, 08:41 PM   #20
saab4life93t's Avatar
does anyone have apart # of 1805 belt that i can get at autozone??
1999 9 sold
1995 9k aero sold
1994 9k aero current
2002 viggen current
saab4life93t is offline
