impossible to remove 2nd oxygen sensor - The Saab Link Forums
Old 08-18-2007, 10:56 AM   #1
Trollerator
abdukted1456's Avatar
I have the DP off, and I need to transfer the second 02 sensor back to my stock DP.
I have soaked it in liquid wrench probably 10 times in the last two days. I tried a wrech, a ratchet with 02 socket, moved to a longer ratchet for more leverage, sprayed more liquid wrench....
it just will not even begin to budge.
any ideas before I just order a new one and sell the DP with an 02 sensor in it??
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 08-18-2007, 11:02 AM   #2
VWSAABVT's Avatar
propane torch and an o2 sensor socket or box end wrench.
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 08-18-2007, 11:06 AM   #3
Trollerator
don't have a torch... I need it off before wednesday.... or I have to sell it with the stupid sensor in there
1990 900 turbo vert
2004 9-5 aero sedan
Old 08-18-2007, 11:16 AM   #4
HNNLIC
Blaque's Avatar
More elbow grease should work. Also try putting it in a vise using an wrench w/ a hammer.
Blaque is offline
Old 08-18-2007, 11:16 AM   #5
mcrowley's Avatar
Stick a pipe over the end of the wrench or the ratchet for more leverage.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-18-2007, 11:17 AM   #6
VWSAABVT's Avatar
home depot has propane torches for about $30, and they are always handy to have around.
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 08-18-2007, 11:19 AM   #7
JK
JK's Avatar
What I have don is to stock the 02 sensor in my bench vise and use the downpipe as the "wrench" always worked well for me.
always a SAAB guy at heart
JK is offline
Old 08-18-2007, 11:22 AM   #8
Trollerator
crowley I don't suppose you have a bench vice???
1990 900 turbo vert
2004 9-5 aero sedan
Old 08-18-2007, 03:01 PM   #9
DeLorean's Avatar
agreed, and you have got to put some heat into it.
I ruined an 02 sensor about 3 weeks ago trying to extract it from a downpipe it was just totally seized into. ended up ripping out the 02 sensors threads, and got it to just spin, and it still would not come out! So it might not be too bad of an idea to just give up if you have it in a vice with a 4 foot breaker bar on there and it still won't move.
DeLorean is offline
Old 08-18-2007, 04:06 PM   #10
132417SAAB's Avatar
selling a DP? already sold?
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 08-18-2007, 04:25 PM   #11
Red DIC's Avatar
stop being such a sally and just get it out.
Red DIC is offline
Old 08-18-2007, 04:42 PM   #12
Bullseye's Avatar
I second the motion for a vise. Put the O sensor in the vise and turn the dp. Leverage is your friend. Heat will help too, but you have to get it pretty hot to do any good.
Let this be a reminder. When you install a new O2 sensor or swap it to your new DP, use a little never seize.
"If guns cause crime, all of mine are defective." T. Nugent
Bullseye is offline
Old 08-18-2007, 05:40 PM   #13
Trollerator
great advice.
1990 900 turbo vert
2004 9-5 aero sedan
Old 08-18-2007, 05:59 PM   #14
NahumCC's Avatar
Dan just run by a local mechnaic. Mine was the same way on the rear when installing my GS pipe and they zipped it out in 2 mintues with an air gun and a little heat.
2013 FR-S
NahumCC is offline
Old 08-18-2007, 06:11 PM   #15
mcrowley's advise is good. i do that all the time with seized lug nuts on my c900 wheels. and when it FINALLY comes loose, there's gonna be this big bang from the pipe hitting against the ratchet... its fun, dont hurt urself...
Saaboy is offline
Old 08-19-2007, 06:21 AM   #16
StX221's Avatar
air tools and 02 sensors??
you need a better mechanic....
dukted, leverage is your friend in this one.
and p.s. make sure you are turning the right way i think i remember something like this before...
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 08-19-2007, 06:26 AM   #17
NahumCC's Avatar
Eh it worked. I brought the downpipe in with the rear o2 sensor in it still. Sensor was fine and it still works.
2013 FR-S
NahumCC is offline
