White smoke from exhaust - The Saab Link Forums
Old 07-25-2007, 11:57 PM   #1
I recently bought a 1995 saab 900 se turbo convertible. I have noticed that every so often puffs of white smoke will come out of my exhaust. I've noticed a small amount of smoke quite a few times when stopping at lights. Then i'll also notice it if I crank the wheel most of the way over for a turn or leaving a parking stall. My car was leaking fluids so originally I had thought that oil was leaking onto my exhaust. So I took the car to the shop and had the mechanic find where the leak was coming from. My power steering pump had a leak, but there was no oil leak. I got a new psp hoping that the white smoke would cease but it hasn't. Any thoughts?
Marcello is offline
Old 07-26-2007, 12:01 AM   #2
what kinda fluids is it leaking when you're turning hard? greasy stuff? can you hear any abnormal sounds when making a very tight turn?
Saaboy is offline
Old 07-26-2007, 02:40 AM   #3
saab4life93t's Avatar
that sounds like its time for a new head gasket...
1999 9 sold
1995 9k aero sold
1994 9k aero current
2002 viggen current
saab4life93t is offline
Old 07-26-2007, 03:29 AM   #4
mcrowley's Avatar
White smoke = coolant
Blue smoke = oil
Black smoke = fuel.
Sounds like a small hg leak to me too.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 07-26-2007, 03:36 AM   #5
stromer's Avatar
Pay attention to the hard steering part and see if that is doing it as much. That seems unrelated to white smoke which, as mentioned before, is likely your head gasket. What is happening is your coolant is being burned up slightly as it is leaking into the engine.
How drastically is your coolant level going down? I'm going to guess you haven't noticed it yet, so you should have a little time. But don't wait too long as head gaskets get progressivly worse and you will have coolant mixing with your oil which will impair lubrication quite a bit.
Start researching good local repair shops now!
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 07-26-2007, 05:07 AM   #6
Johnz826's Avatar
Send a message via AIM to Johnz826
I definitly agree, but it could also be a cracked turbo too, could have sworn someone here in this forum had a cracked turbo housing and coolant was leaking into the exhaust side.
SAAB like no other!!!
status: Engine died, car sold
Johnz826 is offline
Old 07-26-2007, 05:12 AM   #7
laxian55's Avatar
I thought i did a few months ago, but it was just a really light blue smoke from the oil. There is almost no way that a turbo can blow a coolant seal and leak coolant into the exhaust. It it possible but rare for it to blow and mix with the oil, in which case you would have milky oil.
laxian55 is offline
Old 07-26-2007, 05:48 AM   #8
Johnz826's Avatar
mmmmmmm milky oil.....maybe it wasn't from this forum but i do recall someone did have a cracked turbo and coolant was leakin into the exhuast part and not in the bearing part, but i know wat u mean, that would definitly ruin ur day if u had milky oil. Play it off, say it's a new type of oil that just came out
Johnz826 is offline
Old 07-26-2007, 05:51 AM   #9
laxian55's Avatar
I dont think the car would be driveable if you cracked the housing that bad.
laxian55 is offline
Old 07-26-2007, 07:05 AM   #10
Johnz826's Avatar
Trust me it wasn't driveable after it started smoking for about a minute, according to the person. Car wouldn't start had to have it towed from where he was.
Johnz826 is offline
Old 07-26-2007, 07:11 AM   #11
laxian55's Avatar
Wow im not even mad, im impressed.
laxian55 is offline
Old 07-26-2007, 07:18 AM   #12
dan-the-kid's Avatar
LOL
dan-the-kid is offline
Old 07-26-2007, 07:40 AM   #13
Johnz826's Avatar
I believe there is a miss understanding of how you read my response, i just simply said in other words ur right it wasn't driveable, i should have worded it better, my bad. I don't get mad on forums, i find no reason to ever. lol but i do laugh at others that do.
Johnz826 is offline
Old 07-26-2007, 07:42 AM   #14
It had been leeking power steering fluid, but ever since I fixed the psp it hasn't been leeking fluids or making any abnormal sounds when I turn. Just white smoke every so often. Thanks for the replies everyone.
Marcello is offline
Old 07-26-2007, 07:44 AM   #15
laxian55's Avatar
its a quote from achorman, i was just jokin around.
laxian55 is offline
Old 07-26-2007, 08:28 AM   #16
I had a bearing split in my turbo, but that caused a James Bond style white smoke screan of white.
