A/C Compressor won't cycle... - The Saab Link Forums
Old 07-03-2007, 10:14 AM   #1
srp
srp's Avatar
Send a message via AIM to srp
Just the other night I was cruising down the highway and had the A/C on about 68 and it was working nicely. I stopped for some dinner at a local diner.
Came back to the car and started it up and the windows fogged up hardcore. It was VERY humid out. Hit defrost and noticed that the A/C compressor did not kick on. Thus no defrost.
Ran the diagnostic check through the ACC panel. No faults.
Everything that has turned up in a search has pointed to the over-temp switch on the compressor or the anti-frost switch on the evaporator. The belt moves freely and no unusual noises from the compressor when it was working.
I actually checked the system charge a month ago and it was good. It has always worked well but I have always thought that it put way more drag on my engine then any other car with A/C I have had. Feels like it was shaking the whole car when it was engaged.
Does this diagnosis sound good so far to anyone else that has experienced this problem?
I will have some garage time this evening to actually diagnosis the system. Anything else to look for?
srp is offline
Old 07-03-2007, 10:49 AM   #2
dan-the-kid's Avatar
I think theres a way to check if its the switch on the compressor is working or not. Maybe some on else can tell us.
Also I think those compressors use an electromagnetic clutch to engage, so maybe thats worn out as well.
These are just some more ideas.
dan-the-kid is offline
Old 07-03-2007, 10:51 AM   #3
I have the same problem and would like to know how to resolve this issue
hkayssi is offline
Old 07-03-2007, 05:45 PM   #4
srp
srp's Avatar
Ok...
Did the troubleshooting that the WIS lists for "Poor or no AC". It basically runs me through testing all relays, fuses and the pressure switch. All of which test fine.
I ended it with testing the lead that goes to the compressor. It shows 14 volts while running. With all these tests completed I can now say that the problem lies with the compressor.
So it's either the thermal shut off switch or the clutch.
It's very tight down there and hard to see. Does anyone know if the thermal switch can be bypassed or if I can run 12 volts directly to the clutch to activate it?
srp is offline
Old 07-03-2007, 05:55 PM   #5
I think you should be able to run the compressor from the batt, but don't take my word for it. And if its the clutch, get a new compressor.
Old 07-03-2007, 06:25 PM   #6
kalvinr11's Avatar
You should be able to run battery voltage to the clutch to see if it engages. Just don't do it for too long. If the thermal switch is bad, this may make the clutch not engage at all.
I think codesplice is dealing with the thermal switch problem on his car too. I think.
-Mike
'99 Viggen with 205k
Status: Mostly OK and studded winter tires
kalvinr11 is offline
Old 07-03-2007, 06:42 PM   #7
srp
srp's Avatar
But is that wire coming off the compressor the only wire I can tap into? If so then I don't think it'll work because I think that wire goes to the thermal cutoff switch before it goes to the clutch... I already have 14 volts at that wire...
srp is offline
Old 07-03-2007, 07:24 PM   #8
codesplice's Avatar
Yeah, I'm dealing with the thermal switch issue on mine. After mucking about with it, I *think* I was able to bypass all the magical safeties on the compressor (thermal switch, frost switch thinger, etc). That is, I can get the compressor to engage using full manual control. Still no cold air, so I'm thinking it's a refridgerant issue now. Maybe. Gonna get my buddy at Meineke to recharge my A/C at some point.
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 07-03-2007, 08:39 PM   #9
srp
srp's Avatar
Code, How did you bypass the thermal switch?
srp is offline
Old 07-03-2007, 10:18 PM   #10
codesplice's Avatar
Honestly.... I don't remember. I'll take a look at it tomorrow and see if I can figure out what I did
2007 9-5 2.3T Wagon
Old 07-04-2007, 06:12 AM   #11
StX221's Avatar
just swap out the compressor with a used one. i picked one up for my 9-5 used for 100 bucks. it went in yesterday in all of an hour and a half. then half hour to charge it, and it blows cold. i need to evacuate the system again, vacuum it down, and recharge it again...to get it really cold.
but i hear your pain. when i pulled it out, i couldnt even spin the clutch by hand, and the pulley sounded like it was grinding enough to be shakira. it was well worth it for a good used one!
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 07-05-2007, 09:30 AM   #12
srp
srp's Avatar
You didn't replace the drier when you did it?
srp is offline
Old 07-17-2007, 09:17 AM   #13
srp
srp's Avatar
Update:
I picked up a used A/C compressor from a recycler off ebay.
Purchased receiver drier, o-rings and PAG oil.
Drained oil from new to me compressor and followed the WIS guidelines on how much oil to add. One of the techs stayed behind to give me a hand. We recovered the refrigerant and threw everything in. No complications at all.
Then we tried to fill it.
We vacuumed it out and filled it with 1.75lbs of r134a. Started the car and turned on the ACC on low recirc. Started to get cold but the pressures started to shoot up really high. High side was about 250 and low side was climbing up around 90 I want to say.
So tonight he is going to recover, vacuum and refil again.
I'm hoping my expansion valve is not messed up...
srp is offline
Old 07-17-2007, 01:37 PM   #14
Good to hear, hopefully it just needs to be re-filled again.
Old 07-17-2007, 02:44 PM   #15
kalvinr11's Avatar
250 sounds a bit high even for the high side. When you shut the car off, did both sides equal out (with gauges still attached and open)? That is important to take note of and can lead to other issues if they don't equalize in a timely manner. I think my TXV may be sticking because I have fresh 134a in it and still have mediocre A/C performance in hot weather.
-Mike
Old 07-17-2007, 05:00 PM   #16
Have you done a system diagnostic? I think you press Auto and Off at the same time. Do that and you'll see if you have any faults, if any number other then 0 shows up, then you have a problem.
Old 07-17-2007, 08:03 PM   #17
srp
srp's Avatar
Don't remember if the low and high side equalized afterwards. I will check tomorrow. I have a feeling I will be doing an expansion valve this weekend.
I did a diagnostic 2 or 3 weeks ago when my A/C first went out and there were no faults. I am kinda afraid to run the system with the pressure that high but maybe I will do another system check tomorrow.
srp is offline
Old 07-17-2007, 08:30 PM   #18
Good. Report back then.
Old 07-19-2007, 02:21 PM   #19
kalvinr11's Avatar
I don't think that the diag system in the ACC will give you any faults as to an A/C compressor not cycling. It should only be to tell you about things likes damper doors not opening or electrical faults in dash area that control said dampers.
I wouldn't be too worried about driving with those pressures. As long as your cooling fan is on when the A/C is, your high side pressures should be ok. Plus there should be a high pressure cut off switch that will stop the compressor cycling if it gets ridiculously high.
-Mike
Old 07-19-2007, 06:07 PM   #20
srp
srp's Avatar
Yeah... As soon as the fan kicks on the high pressure shoots way down... I'd still prefer the system to be more "in spec". Haven't gotten around to futzing with it more.
srp is offline
