FCUK this viggen! - The Saab Link Forums
Old 05-12-2007, 11:22 AM   #1
saabkid37's Avatar
FCUK this viggen!
THIS DAMN THING JUST DOESNT WANT TO COOPERATE.
did the pcv #6 update and put on the saab sport. started it up and it ran for 3 minutes or so and then just shut off while throwing a code and now wont start.
its throwing code P1230 which in mitchell is tps voltage out of range (im gonna be pissed if it is since thats a 400 dollar part)
but on the scanner 1230 comes up as slow fuel pump, but when you turn the key to on you can hear the fuel pump prime.
there is also a loud ticking that seems to be coming from the black hosing on the drivers side of the TB.
any ideas?
this is slowly ending my hopes of going to carlisle....
saabkid37 is offline
Old 05-12-2007, 11:44 AM   #2
JK
JK's Avatar
Definatly sounds like a elec. throttle issue
always a SAAB guy at heart
JK is offline
Old 05-12-2007, 12:04 PM   #3
Trollerator
abdukted1456's Avatar
what is mitchell?
if I can get my other pc up later I will look in WIS for you
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 05-12-2007, 12:11 PM   #4
SPG-GASM's Avatar
You will hear a series of five clicks with the ignition is turned on that is saying that the tb is going into a limphome mode you pull off that metal cover by the dipstick you will see the throttle linkage there are two levers and if the one lever is further back towrads the firewall then it is in limphome mode. YOu can try and take your battery cable off and rest the linkage, what you hae to do is take a flat screwdriver and pull up on the little wire that rests against the lever and raise that lever(which the wire was against) and move it above the lever on the other side(furthest from the tb opening)
SPG-GASM is offline
Old 05-12-2007, 01:20 PM   #5
saabkid37's Avatar
well after finding i could start and run it if i controlled the throttle, i cleared the codes and it ran and idled for 10 minutes. code stayed off...we drove 10 miles and got p1251 which didnt affect anything, cleared that while driving and it has been fine since, and its definetly not in limp mode cuz it pulls like a mofo. so we shall see now.
all we did was take off the connector and clean it and plug back in.
Old 05-12-2007, 01:48 PM   #6
drewz airflow se's Avatar
Welcome to T7 cars....
^CLICK ME^
drewz airflow se is offline
Old 05-12-2007, 03:29 PM   #7
saabkid37's Avatar
yeah this is bullshit, hopefully the tb isnt actually dead, and will be fine, or im not going to carlisle. we'll see how this week goes.
Old 05-12-2007, 09:37 PM   #8
StX221's Avatar
the electronic throttle body is a pain. but when they work, they are amazing with what they can do.
fyi, a new one from eeuro is like 268 (iirc). thats still a pretty darn high price, but better than the 4 or 500 that a dealer would want.
you can probably find a good used one too.
EDIT: did you try cleaning the throttle body? with throttle body cleaner, and moving the throttle plate by hand to clean all around it?
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 05-12-2007, 10:08 PM   #9
We have mitchel at my auto shop class. Would you recommend trusting it?
Saaboy is offline
Old 05-13-2007, 06:27 AM   #10
saabkid37's Avatar
yeah mitchell is fine.
i thought i saw 415 for a tb on eeuro. but its been working for 24 hours so we shall see.
Old 05-13-2007, 06:32 AM   #11
spgproject's Avatar
those throttle housings are relativly common to fail like this. 1230 and 1231 are the norm for codes from them.
good luck.
-Sir William Lyons
spgproject is offline
Old 05-13-2007, 06:59 AM   #12
StX221's Avatar
it is 425.....gasp!
i bought mine on 8/17/2005, and it was $266.05 from eeuro
damn the price went up.
genuine has them for 392...they got pricey!
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 05-13-2007, 07:18 AM   #13
mcrowley's Avatar
...and you people talk shit about electronic throttle bodies in 9ks
Good luck!
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 05-13-2007, 08:00 AM   #14
StX221's Avatar
i have never once said anything about electronic tb's in a 9000.
its cheaper for you to have yours rebuilt now though...
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 05-13-2007, 08:33 AM   #15
josuar88's Avatar
Send a message via AIM to josuar88 Send a message via MSN to josuar88 Send a message via Yahoo to josuar88
damn that sucks man I've heard only good things about viggens
josuar88 is offline
Old 05-13-2007, 11:21 AM   #16
PM sent.
kwkslvr is offline
Old 05-13-2007, 03:55 PM   #17
saabkid37's Avatar
well...now it threw p1230 again, and also p1260 which on my scanner shows up as theft detected car immobilized haha.
1260 is really something about the throttle return spring not having enough tension....so i really think this tb is toast.
and now i drobe the 9k for the first time since january and after 60 miles it went into base boost 100 feet from my drive way...son of a bitch.
Old 05-13-2007, 04:36 PM   #18
JK
JK's Avatar
Sounds like both of these cars you have are suffering from lot-rot
JK is offline
Old 05-13-2007, 04:38 PM   #19
spgproject's Avatar
honda = distraction
-Sir William Lyons
Old 05-13-2007, 04:38 PM   #20
saabkid37's Avatar
nah the viggen has been my dads daily (200 miles/day) since we bought it.
