Burning Oil 01 Viggen - The Saab Link Forums
Old 09-03-2017, 12:30 PM   #1
Seems that I'm burning 1.5-2qts oil per 250miles No leaks. Doesn't seem like I'm chuffing blue smoke either, a little blue on first startup of the day but I'm also getting a CEL for a bad cat. I hear my PCV could be causing this?? I was planning to upgrade to PCV6 soon just as preventative. Any ideas Saablink?
autodog221 is offline
Old 09-04-2017, 11:29 AM   #2
lms
How old is the turbo, the seal might be leaking? A bad pcv valve can also cause a little, but usually it causes leaks. Change it asap.
lms is offline
Old 09-04-2017, 04:21 PM   #3
Drew In Houston
I'd do a compression check first, then suspect the turbo like lms wrote. 1.5 - 2.0 qts in 250 miles is really bad, I'm skeptical that a PCV problem could even cause a loss of that magnitude.
Did it get to this state gradually over time or more suddenly?
Trionic3000 is offline
