No Spark not the same as the rest - The Saab Link Forums
Old 02-01-2017, 05:54 AM   #1
sleeper93's Avatar
No Spark not the same as the rest (Solved)
Ok so yet another no start no spark, I just got this beautiful Black viggen look a like and want to get her running. The PO said that she would crank then start for a second then die. I was able to get it to do so once or twice but now just cranks and cranks. Feels like a slow crank even when hooked to jump box. Pulled old plugs (denso ik???) they were wet and cylinder 1 was melted or came into contact but there is no impact scars on the piston.
2003 Convertible 9-3 se
Have fuel pressure at the rail,
Replaced CPS with one out of donor,
Replaced plugs (NGK BCPR6es-11),
checked for vacuum leaks,
Replaced battery,
Replaced DIC with Brand new and tried Known Good,
Edit:
(solved)
So to Update everyone I went and got a new CPS and installed it and had the same issue so I dug deeper and went to replacing vac lines and such. When I cleaned the throttle body I noticed that the butterfly was not opening with the throttle cable. I guess the spring crapped out. Replaced with one from one of my donors. She is purring like a swedish kitten. Now to finish the vac lines and adjust idle some reason it's holding steady at 1.5k and only drops if in gear.
sleeper93 is offline
Old 02-01-2017, 06:11 AM   #2
Wagon Shaggin'
Saabeh's Avatar
How about the DI Cassette?
Saabeh is offline
Old 02-01-2017, 06:18 AM   #3
sleeper93's Avatar
Sorry yes I Replaced DIC with Brand new and tried Known Good, (updated post)
My Saab's give me a God Complex
Old 02-01-2017, 06:20 AM   #4
Wagon Shaggin'
Saabeh's Avatar
Look closely at the tachometer when you are cranking the engine, see if it jumps slightly as the engine is turning over.
Saabeh is offline
Old 02-01-2017, 06:32 AM   #5
sleeper93's Avatar
It did not appear to be bouncing but I have also found this test to only work some of the time with other CPS issue Saab's I have worked on.
Old 02-01-2017, 07:00 AM   #6
Wagon Shaggin'
Saabeh's Avatar
I have had brand new CPS bad out of the box and typically only buy the Bosch OE ones. Would be definitely worth double checking the CPS and the wiring/connector.
Saabeh is offline
Old 02-01-2017, 09:22 AM   #7
sleeper93's Avatar
I am going to pull the one out of my daily (9-5 tonight and try that.
Old 02-01-2017, 09:37 AM   #8
DrewP's Avatar
If one of the plugs was melted, check the compression. An easier way to check the CPS is with a fuel injector test light (noid light) - if you get flashing at the injector harness when cranking then the CPS is fine.
DrewP is offline
Old 02-03-2017, 05:45 AM   #9
sleeper93's Avatar
Old 02-03-2017, 06:10 AM   #10
Wagon Shaggin'
Saabeh's Avatar
Um, its not supposed to actually. The throttle cable should not move the butterfly manually until its in limp home mode. The TB is electrical obviously. If you watch the silver cam looking piece on the TB and rev the engine with your hand on the throttle cable, the cam looking piece moves on its own based on what the ECU thinks is appropriate.
I have never seen a TB cause a total no start. I have a feeling there is an electrical gremlin or some loose connector.
Saabeh is offline
Old 02-03-2017, 06:33 AM   #11
Drew In Houston
Yep, second Saabeh's comment.
It sounds like you may have replaced a good throttlebody with a bad one. If you don't have it already, you'll definitely get a t-body related CEL as soon as you try to drive it and it'll run like crap.
These things are throttle-by-wire, meaning there's a motor in there that actually controls the position of the throttle plate--and the normal situation is that the throttlebody input where the throttle cable connects is disconnected from the butterfly. When things are functioning correctly, there are redundant 0-5V and a 5-0V position sensors inside the t-body--the ECU performs subtraction on the two voltage levels, and the result needs to be a continuous 2.5V =/- some error tolerance.
Those two internal sensors measure the position that the throttle cable moves the input to the throttle body, report that position to the ECU, and then the ECU drives the signal for the throttle plate position, and then the t-body moves the plate.
The safety is a one-shot solenoid, that if something fouls up, activates and connects the throttle plate directly to the throttle cable. If the butterfly is moving with the cable, that means it's in limp home mode and that solenoid activated.
Look on here for how to reset the limp home solenoid, it's a manual procedure, and you'll have to clear the CEL at the same time, otherwise it'll just reactivate the limp home solenoid. You'll hear it clicking around.
Trionic3000 is offline
Old 02-03-2017, 06:35 AM   #12
sleeper93's Avatar
I know that every pre MY saap I have and have had are all controlled by the trottle cable and yes they are also tied into the ecu by means of the harness allowing control over limp mode and cold start since iac valve was done away with in the 9-3's. See link for diagram of TB https://www.google.com/url?sa=i&rct=...86222448189434
Old 02-03-2017, 06:39 AM   #13
Drew In Houston
Okay, I don't know what you're trying to say here and the link is just a picture to buy a throttlebody.
But read what I wrote, look up how to reset the limp home mode, clear the CEL at the same time, and listen that it doesn't click and re-engage the solenoid.
Old 02-03-2017, 06:39 AM   #14
sleeper93's Avatar
I do believe that the old TB could have had a fried circuit or something as I did check the harness for any burns or exposed wire and found nothing for concern. On the old TB when using the black arm to open or close the butterfly it would not ingage the silver lower arm. I attempted to do a limp reset on the TB but to no avail.
Old 02-03-2017, 06:42 AM   #15
sleeper93's Avatar
I will take a picture a little later but to me it looks as if the 2 lower points of the spring on the side had somehow jumped the plastic piece stopping the 2 arms from moving together.
Old 02-03-2017, 06:43 AM   #16
Wagon Shaggin'
Saabeh's Avatar
After dealing with limp home mode a few times, you'll be an expert. But again, the butterfly and throttle cable on ALL T7 Saabs are NOT directly connected unless its in limp mode.
Saabeh is offline
Old 02-03-2017, 06:43 AM   #17
Drew In Houston
Is the throttle plate moving when you move the black arm where the cable connects?
If it does, you're in limp home mode and it's not right.
Old 02-03-2017, 06:57 AM   #18
sleeper93's Avatar
Before I swapped the TB out I tested by unplugging 1 connector at a time starting with the small connector just behind the valve and trying to start it would not move, Then the large harness connector again would not move nor start. I then wedged it open by means of the silver arm and a wrench and it fired up. So yes it could very possibly be the internal components of the TB or a fault somewhere in the wiring. To be honest I did not check movement of the replacement TB once installed as I know it started and is driving nice other then the high idle issue.
Tags
crank no start, no spark, no start
