2001 9-3se OBII Codes 1304, 0304, 1260 - The Saab Link Forums
Old 09-13-2016, 12:42 PM   #1
Hi all,
I'm impressed at all of the saabers still active on these forums...its great to see!
My teenager just got a used 2001 9-3se convertible 2.0L with about 85k miles. The dealer replaced the DIC after a CEL came on during our test drive. After a week of running fine, the engine is misfiring terribly and read error codes 1304, 0304, and 1260.
I've read a ton of these forums, but I'm hoping someone will be able to point me in a better direction...
We've tested a different DIC which we know works, put in new NGK plugs (factor gap at .39"), added in octane booster (he put 87 octane in the tank), and ran a compression test. 1=60 first and 90 after adding oil 2=150 3=150 4=150
Couple of other random notes:
The car was in limp home mode, I cleared it, it has not come back on. There's slight buildup in the TB.
Oil leak (from OPS most likely).
Hoses & wires have seen better days.
Engine runs way too hot.
I plan on cleaning the MAF, replacing the PCV hoses, cleaning out the oil pan for sludge, flushing the radiator, and potentially cleaning out the TB.
Thoughts?
Thanks,
Dave
thirdout is offline
Old 09-13-2016, 12:44 PM   #2
and yes that is supposed to be .039" gap on the plugs
thirdout is offline
Old 09-14-2016, 04:36 AM   #3
I think that compression test says it all...
seriks1 is offline
Old 09-14-2016, 08:39 PM   #4
Drew In Houston
Agree, sounds like a cracked but still in place piston
Trionic3000 is offline
Old 09-15-2016, 10:45 AM   #5
Also feel the compression test is telling. If you do anything, drop the oil pan first. Take a close look up into the offending cylinder and see if you can see scoring on the culinder wall when the piston is at TDC. that should help narrow it down between a cracked piston and stuck rings. If you find sludge in the pan my vote is for stuck rings and scored cylinder wall. That seems most likely.
Tboy is offline
Old 11-10-2016, 10:45 AM   #6
Compression Repair Additives
Sorry for the late response, I thought I'd get an email notification of responses to my thread and didn't know anyone responded!
I just saw the responses and haven't taken any huge leaps into examining the piston or rings yet.
To add what I described earlier, we found that adding Rislone compression repair or Restore completely clears the misfires while idling or in gear (except reverse!) for about 2-3 weeks. Then the misfires begin again with misfire codes for cylinder 1 only (makes more sense than the cylinder 4 codes from before).
Any pointers or what-to-watch-out-for tips in dropping the oil pan? I took a look and it would appear to be a massive job as the exhaust is in the way, let alone access to disconnect the pan itself.
Thanks!
Dave
thirdout is offline
Old 11-10-2016, 11:28 AM   #7
Drew In Houston
The oil pan isn't hard, the biggest pain is if your exhaust studs/bolts break or are siezed. There are only 5 though. 3 on the downpipe to turbo flange and 2 on the downpipe to midpipe coupler. Other than that there are two external bracket bolts.
I wouldn't bother though. I'm pretty sure you have a piston that's cracked; it probably hasn't caused a lot of scoring (maybe not any), otherwise the liquid magic stuff probably wouldn't work.
I'd pull the head and pan together if anything; you can get a used piston and new ring set, do a quick ball hone, and put it all back together with a new head gasket for pretty cheap.
Old 11-10-2016, 05:15 PM   #8
Thanks a lot for the input. What would most likely cause a cracked piston?
thirdout is offline
Old 11-11-2016, 02:57 PM   #9
Drew In Houston
Is there a lot of oily buildup around the dipstick tube? That's another indicator.
For causes I think there are a few different failure contributors. The coding/calibration isn't very tolerant of failing or slow responding mass air flow meters or failing/slow responding O2 sensors and 2001 was also the second year of lighter weight pistons.
One issue is that the factory calibration for how long the engine will run in closed loop mode while load is increasing is very long--meaning that load has increased, but the fueling has not yet enriched. That's potentially better for emissions, but if you have a slightly out of calibration mass air flow sensor that's reading a little low on the real mass of air, that quickly can cause lean running, detonation--especially on low octane fuel--and because the pistons aren't over built, a crack.
Years ago talking with Nick Taliaferro at Genuine Saab, who has seen many more instances than I have, he told me that it's pretty typical to see cracks in between the ring lands, which I have seen (and why I was talking with him about it).
Old 11-12-2016, 04:10 AM   #10
I appreciate the info!
thirdout is offline
