really could use some troubleshooting help... - The Saab Link Forums
Old 07-15-2016, 06:53 PM   #1
So, after replacing my radiator my 900 se quit running. it started with long start times, and graduated to no start condition. ive replaced the DI cassette, the cps, checked fuel pressure...nothing. Today i replaced ecu, the relay below it, and started working through the WIS diagnostics steps. anyone have any ideas on a cause?
ardenconstructionca is offline
Old 07-17-2016, 10:50 AM   #2
Are the plugs wet with fuel after prolonged cranking? Did you remove any sensors to get the radiator out? I also don't know how you checked fuel pressure since there is no schrader valve on the rail or line. The fuel system in these cars is prone to issues relating to either the pump or the relay for it. I would give it a shot of starting fluid and see if it starts. This is a very easy way of determining whether or not it is a spark related issue or a fuel related issue. The radiator job may be coincidence. Nine times out of ten, it is either the fuel pump or the fuel relay that leads to a no start condition. The rest of the time it is a TPS or CPS issue. Did you replace it with the right cps? They make 2 versions that look almost identical and have the same connector; one is for the NA variant, the other is for the turbo.
-Cm
Cm452 is offline
