Sounds like Sway-Bar Link; Isn't - The Saab Link Forums
Old 04-19-2016, 08:42 PM   #1
This problem presented about a year ago and has gotten worse. If anyone has had a swaybar link go bad, or come loose in the control arm, and experienced that "knnaaknockknockknock" over bumps/oscillations in the road surface, this is exactly what it sounds like, under the same conditions. It's on the passenger side of the car (LHD)
However, I've jacked the car up and the pried the sway bar and drop links to test for play, or for shot sway-bar+droplink bushings--everything is tight as hell. The inboard bushings--the ones that mount to the subframe--display no slop whatsoever when I really bitch that swaybar around, too.
The spring does not appear broken, nor does the perch, and the tie-rod ends are tight too.
I've had a friend or two bounce on the car while I checked to see if the strut mount was causing the noise--silent, although the inner bell does move around a bit.
Control arm bushings are tight as well, and so too are the caliper carriers on the brakes (had that happen where the caliper carrier bolts backed out and it made the same sound as a bad droplink)
What could it be?
-Cm
Cm452 is offline
Old 04-20-2016, 02:33 AM   #2
Drew in Houston's Avatar
Bet it's a loose strut collar (?)
Drew in Houston is offline
Old 04-20-2016, 09:53 AM   #3
or the bushing that holds the sway bar to the subframe
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 04-20-2016, 12:48 PM   #4
Is that the threaded ring that holds the actual shock inside the strut, because that is tight too.
The bushings that mount to the subframe that hold the swaybar in place are also tight as far as I can see.
-Cm
Cm452 is offline
Old 04-20-2016, 03:43 PM   #5
-Cm
Yeah that's what I meant; that may not be your problem though, I had one that seemed tight but wasn't, and the symptoms seem to line up. For some reason on one 9-3 I had, the driver side kept getting loose.
After tightening it a few times I finally used a pipe wrench and made it really tight, that fixed it. I don't know what you're using to check tightness but if you have a pipe wrench you could see if you can turn it tighter, would only take a few seconds because you can do it through the coil springs with the car on the ground.
Otherwise, maybe the strut bearing like Craig said, they can fall apart in there? Check the center lock nut too I guess. Steering arms and stuff are tight too? I think between me you and Craig we've just listed all the moving parts now, if it's not one of them, then maybe engine mount or something else incidental that's moving?
Old 04-20-2016, 07:44 PM   #6
I've already replaced the engine mount on the passenger side, as it was worn, and I thought the noise might be the engine tapping the frame rail. New mount did nothing to help the problem. As far as I can tell, everything is tight!
Cm452 is offline
Old 04-20-2016, 08:03 PM   #7
srp
srp's Avatar
Send a message via AIM to srp
I had a similar noise that only appeared when turning one direction and hitting a bump. It was the strut collar. I fixed it exactly how Drew described; a small 8-10" pipe wrench through the spring with a cheater bar.
srp is offline
Old 04-22-2016, 04:31 AM   #8
Nailed it! Was indeed the strut collar. It must have unscrewed itself and then frozen with rust. After really crankin on it, it tightened up in 3/4 of a turn.
Noise is gone!
-Cm
Cm452 is offline
Old 04-22-2016, 06:18 PM   #9
Excellent, glad to help!
