saad turns over will not start - The Saab Link Forums
Old 01-24-2016, 06:07 PM   #1
Angry saad turns over will not start
1995 SAAB 9.3 convertible. Won't start. No fire, but car turns over. headlights are on, but interior dash lights out. electric windows and convertible top will not come on. Battery has drain and cannot find it. Have checked all fuses and circuit breakers and all good?
randj is offline
Old 01-25-2016, 07:00 AM   #2
I suppose you mean a ng900. Anyway, do you have the V6 or the 4 cylinder 2.3, or the Turbo? It is commonly the crankshaft position sensor (cps), the throttle position sensor (tps) or the fuel pump and/or relay.
-Cm
Cm452 is offline
Old 01-25-2016, 09:51 AM   #3
turbojohnny's Avatar
it is very likely that you have a bad alternator and running the car kills the battery. try charging up the battery and if it starts put a multimeter on the battery cables to see what your alternator is putting out. it should be close to 14 volts. anything less than 12volts, your alternator is not doing an ounce of good.
turbojohnny is offline
